Stabilizer Bar
Old Nov 29, 2010 | 04:05 PM
MechEng's Avatar
Default Stabilizer Bar
So I've narrowed down a front drivers side squeaking noise to either by lower ball joint or the bushings for the front stabilizer bar.
I'd like to tackle the front stabilizer bushings first. If I put the car on ramps, can I simply remove the the caps on the bushings to apply grease or is the bar loaded making this unsafe?
Thanks
Old Nov 30, 2010 | 09:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Stabilizer Bar
If suspension is at same height on both sides, then yes you can just unbolt the brackets holding the bushings/bar in place. Either have the whole front end jacked up or on ramps.
Keep in mind that one of the bolts for the swaybar D-bushing bracket also goes through the front LCA compliance bushing bracket. I'm not sure which one needs to come off to get the other one off.
Old Nov 30, 2010 | 03:30 PM
MechEng's Avatar
Thank you
soon2bdropped
10
Feb 27, 2011 11:26 AM
Rizzen
Oct 20, 2008 06:49 AM
CALC!_JUST_du_IT!
Suspension & Brakes
Aug 28, 2007 12:27 PM
broketuner-Sol_Si
Suspension & Brakes
May 5, 2006 02:59 PM
pyrojeff
Apr 25, 2005 06:31 AM
