Electrical Help Needed...
Old Dec 9, 2010 | 12:18 PM
DC2-TEG's Avatar
Default Electrical Help Needed...
I have a '97 GSR.
With the light switch turned off, when I press the brake pedal, my clock dims, and my dash and heater panel illuminate.
With the light switch turned on, when I press the brake pedal no lights change.
As you can read above anytime I press the brake pedal the lights inside the car act as if the light switch is being turned on. This problem has come out of nowhere, it is not directly following any upgrades or mods. I have replaced the brake light switch on the pedal with no change in the lights acting up.
Any pointers? or ideas? Any help is appreciated..
Old Dec 9, 2010 | 02:43 PM
EHondaJDM's Avatar
Default Re: Electrical Help Needed...
Get a new alternator and plan on changing that one in the near future
Old Dec 9, 2010 | 04:08 PM
fcm's Avatar
fcm
Old Fart
Check the tail light ground, also check all the brake light bulbs, a common problem with dual filament bulbs is the filaments will "warp" over time and every once in a while the filaments will touch, if the brake light filament is touching the park light filament every time you step on the brake the park light circuit will power up, if the park light switch is on you would not notice as the park light circuit is already on, turn on the park lights and see if the brake lights are also on. 94
Old Dec 9, 2010 | 04:23 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
wow interesting. Never thought of or heard of that, but certainly sounds plausible.
Old Dec 10, 2010 | 01:24 PM
DC2-TEG's Avatar
Actually yes, when I turn on the running lights, the Brake lights are lit up as if the brake pedal is pressed. I'll try changing the bulbs. Where is this taillight ground you speak of? Doesn't it just ground to the body?
Old Dec 10, 2010 | 03:53 PM
fcm's Avatar
fcm
Old Fart
Yes the tail light ground is grounded to chassis, behind the rear trim panel, remove, [unplug] one bulb at a time and try the lights, it can be hard to see if filaments are touching as the bulb is still "good".
Also inspect the bulb socket, make sure it is rust/debris free, a bad ground on a duel filament bulb will cause the same thing
Unplug a bulb and go step on brake, when park lights no longer turn on, [when stepping on brake] you have found the bad bulb.
We, [Dave Ward Auto Electric] get one or two of these every few months, it can happen to any car that uses duel filament bulbs. 94
91b18a1ls
Mar 19, 2011 10:24 PM
kornkid21792
Jan 21, 2010 03:27 AM
jdmdc2boi12
Honda Motorcycles
Jul 18, 2009 07:37 PM
CRX T-Si
16
Jun 23, 2006 11:30 PM
vinny76010
Apr 20, 2006 12:32 PM
