Integra idle problem
Old Mar 16, 2011 | 07:29 PM
DatDCboi's Avatar
Default Integra idle problem
I have a 99 gsr and just recently my integra has started to idle really funny. Its bouncing between 2k rpm and 1k rpm. I've cleaned my IACV but that didn't fix the problem. The car drives fine its only the idle thats the problem. Any idea what the problem is?
Old Mar 19, 2011 | 02:58 PM
flaco1418's Avatar
Default Re: Integra idle problem
have you checked for any vacuum leaks?
Old Mar 20, 2011 | 03:40 AM
OsakaGunship's Avatar
Dude pop off your throttle body and turn it upside down and see if that white piece came loose if it did just tighten up again happened to me i got GS-R too with b20v now it idles at a cool 800rpms
Old Mar 20, 2011 | 09:44 PM
honda_fan06's Avatar
Could have ruined the iacv by cleaning it, cleaning it doesn't always work sometimes it's just not fixable.
Old Mar 20, 2011 | 11:45 PM
DatDCboi's Avatar
are you talking about a FICV?? I guess I'll check for vac leaks and replace the IACV if there are no leaks.
Old Mar 21, 2011 | 07:13 AM
C4_Gsr_civic's Avatar
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
go here... worked perfect for mine, i also did it without removing the intake mani. but it wasn't exactly easy to get to the back bolt...
Old Mar 21, 2011 | 07:15 AM
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
check this one too
longshot
Nov 30, 2008 10:44 AM
chhonda150
May 4, 2008 05:06 PM
soysauce93integra
Feb 16, 2008 10:21 PM
TheIntegraGuy
Jan 22, 2004 06:48 PM
matt j
Jan 2, 2004 07:21 AM
