OBD1 conversion help!
Old Mar 6, 2011 | 03:12 PM
scia220's Avatar
Default OBD1 conversion help!
ok 91 integra i'm trying to convert to obd1. Bought all my wiring from rywire. Now, before i swapped anything the car started perfectly. Now, i changed the dizzy to an obd1, hooked up the dizzy adapter, unplugged the stock ecu and install the conversion harness and my obd1 ecu. Issue is now, it just clicks but does not start! it doesnt really crank like it's suppose to, it just sounds like the starter is just going but nothing else. I also relocated the battery to the trunk so i checked the ground and everything to make sure it was good and weverything was still intact. Any ideas? i really need to get this problem fixed so i can start my turbo kit and have everything ready for the honda meet we're having here next month. Thanks for the help
Old Mar 6, 2011 | 05:03 PM
scia220's Avatar
Default Re: OBD1 conversion help!
bump. anyone?
Old Mar 6, 2011 | 05:15 PM
mouab18c1's Avatar
So the motor doesn't even turn over?
Jump start it?
Old Mar 6, 2011 | 05:29 PM
scia220's Avatar
welll the battery is fine. everything powers up but when i try to crank it, it sounds like the starter is going but its not cranking the motor. like the engine doesnt turn like its suppose to or something. You know the sound that it makes when you try to start the car but its already on? It makes a sound like that. idk why. I swear its something stupid, it always is lol
Old Mar 6, 2011 | 05:43 PM
91_LS's Avatar
This is going to be the starter bro,the gear isn't popping out to grab the flywheel.
Have someone tap the starter solenoid has you try starting it,that should jump the gear forward.
Old Mar 6, 2011 | 05:47 PM
scia220's Avatar
ok. thats what im gonna try tomorrow because i live in iowa and right now its snowin and like 10 degrees. So when it's light out ill have a buddy help and post an update.
Old Mar 7, 2011 | 04:11 PM
scia220's Avatar
Rywire almost had one coming lol but yeah it was the starter. Gave it a tap and it was all good.
Old Mar 7, 2011 | 05:03 PM
91_LS's Avatar
Coolbeans bro.
Old Mar 12, 2011 | 02:33 PM
scia220's Avatar
Yeah, so that starter problem is fixed but idk what's going on now because it just cranks but doesnt start. Now a friend gave me an obd1 dizzy but i dont it's right for my b18a1 integra because it doesnt bolt up right. But i dont know if its the ecu or the dizzy. My ecu is from pherable and i just burned a stock ls bin. i'm gonna try reburning the chip and convert all over again.
Old Mar 12, 2011 | 11:05 PM
scia220's Avatar
This is the dizzy i got for my conversion. Does this look like the one i need from an obd1 integra? it looks its for sohc to me and only the top leg bolts up..
Old Mar 13, 2011 | 10:33 AM
scia220's Avatar
anyone?
Old Mar 13, 2011 | 04:12 PM
scia220's Avatar
bump..
Old Mar 13, 2011 | 06:06 PM
scia220's Avatar
Just a simple yes it is or not its not right.. ?? nobody
Old Mar 13, 2011 | 06:21 PM
egsleepercivic's Avatar
what is stamped on the dizzy, look for something like td44u(b16a) or similar
Old Mar 14, 2011 | 08:43 PM
scia220's Avatar
It's not stamped anywhere at all. I know there's usually a sticker on there but this one doesnt have any.
Old Mar 14, 2011 | 10:52 PM
all the ones I have had have been stamped into the metal, no stickers
Old Mar 20, 2011 | 10:35 PM
scia220's Avatar
nothing. searched all over it and nothing is stamped. thinkin its for a d series??
Old Mar 27, 2011 | 06:35 PM
89hybrid's Avatar
Yeah looks like my z6 dizzy.
Old Mar 28, 2011 | 11:22 AM
scia220's Avatar
Yeah it was a d series dizzy. Bought a obd1 ls dizzy from ebay and it started up fine. Dude scammed me! That ***** ***** lol whatevs. But yeah it's all good now.
minime-dom
May 19, 2010 06:31 AM
Stunna MIKE
Dec 6, 2008 11:08 AM
drudown81
Oct 12, 2005 08:20 PM
b16powwer
Apr 27, 2004 06:13 PM
filthyCREX
35
Feb 20, 2004 05:36 AM
