steering help!
Old Mar 5, 2011 | 08:10 AM
mapa1229's Avatar
Default steering help!
long story short i had to do a SHARP left u-turn...and ever since then when i am accelerating in the freeway(4th,5th) the steering wheel shakes left and right and the car shakes from the front as if the tires were wobbly, thought it was axles so replacedd both, then after that it started doing that during pretty much all geras till about 65mph...this only happens when i give it gas though...if anybody would happen to know what this could be and let kme know that would be greatly appreciated...
Old Mar 12, 2011 | 08:36 PM
mapa1229's Avatar
Default Re: steering help!
TTT
Old Mar 12, 2011 | 08:41 PM
mark@silbernage's Avatar
Any chance you bent the right front wheel?
Jack it up and give it a spin - you should see it if so.
Mark
Old Mar 12, 2011 | 09:01 PM
91_LS's Avatar
You might of stripped the inner or outer tie rod bro,i would also check the wheel bearing,but i don't think its that.
Old Mar 13, 2011 | 04:02 PM
mapa1229's Avatar
ill check the wheels,
how would i check if its the tie rods?
Old Mar 13, 2011 | 05:28 PM
91_LS's Avatar
Try and wiggle it,if there's free-play,its loose and needs ether tightening or replacing.
Old Mar 13, 2011 | 05:38 PM
MD426's Avatar
Could also be your tires or bent rim? Check them balanced if all else fails.
Old Mar 13, 2011 | 10:49 PM
boydsc33's Avatar
you may also want to check motor mounts and transmission mounts. i have had cars vibrate like that on acceleration and feel fine when coasting. on acceleration the torque can shift the engine if mounts are bad causing drive shaft missalignment and vibration
flyinkman
Jan 1, 2013 01:00 PM
h22pwr
Apr 12, 2006 06:46 AM
ElZRex
27
Mar 21, 2006 09:00 AM
ShadyBAB
Jan 13, 2006 05:58 PM
90lxman
Aug 2, 2005 05:19 PM
