TRASMISSION PROBLEM!!
Old Mar 4, 2011 | 11:01 PM
DrewBrews's Avatar
Default TRASMISSION PROBLEM!!
i got a 94 stickshift gsr with a transmission problem i believe. When im driving in 1st or 2nd gear and let go of the gas, my car jerks and makes a drag noise. In 3rd, 4th and 5th gear isn't so bad, i can still feel the jerk but not as worst as 1st and 2nd gear. It only happens when i let go of the gas pedal. It doesn't do it in neutral, only in gears. Normally in any manual cars, when you let go of the gas when driving, it rolls freely and smoothly then slows down, but in my car, it jerks and makes a raspy sound like something is being dragged, im guessing its a bearing or something because its not rolling smoothly. Let me know what you guys think
Thanks.
Old Mar 5, 2011 | 07:01 AM
Quick99Si's Avatar
Default Re: TRASMISSION PROBLEM!!
roh-roooh
Old Mar 5, 2011 | 07:13 AM
Dogginator's Avatar
Daisy... Daisy...
Does it do this with the clutch depressed while in gear? Any CELs? I think that this in an engine problem, probably a FITV or IACV.
Old Mar 5, 2011 | 08:43 PM
DrewBrews's Avatar
I dont think its an engine problem. Im sure its the transmission. There is no check engine light.
Old Mar 5, 2011 | 09:56 PM
mouab18c1's Avatar
Do you grind shifting from gear to gear at regular driving? WOT?
Again I highly doubt its your transmission.
Old Mar 5, 2011 | 10:07 PM
igorka_91's Avatar
Jerks. Engine Mounts or torque mounts. I had the same issue. Instaled the poly inserts and no more jerking.
Old Mar 5, 2011 | 10:09 PM
Hidenplanvew's Avatar
change the mtf
b18c1ej8
Nov 29, 2010 03:26 PM
oddcivic
Feb 6, 2002 12:18 PM
