Swapping B18A engine into 2000 Integra?
Old Mar 22, 2011 | 08:16 AM
runninclean's Avatar
Icon6 Swapping B18A engine into 2000 Integra?
ok so i have a 2000 acura integra, the timeing belt broke, the motor is shot i already did a leak down test. I want to know if my 1993 B18A1 would fit into the car, i know its obd1 but i have everything to make it a obd2 motor. Is there a difference between and sensors on the block? or anything like that. thanks
Old Mar 22, 2011 | 09:18 AM
97-LS-B18's Avatar
Default Re: INTEGRA HELP!!!
Typiccaly when u do a motor swap and u want it to pass smog u would want to use all the smog equipment that was on that car with the new motor becouse if it doesnt put out the right exhaust it will kick the o2 sensor light on or even a check engine light on and any car with a check engine light or o2 light on the smog shop wont smog it so try to keep all the smog equipment the same so it will put out the right exhaust fumes specified for that car hopefully this helps and goodluck with the swap
Old Mar 22, 2011 | 12:47 PM
Default Re: Swapping B18A engine into 2000 Integra?
Thanks
Old Mar 22, 2011 | 05:09 PM
djkobe's Avatar
i would think that you would need to make the car obd1 instead of converting to obd2 but dont qoute me on that because im not positive. hopefully someone with more knowledge will chime in with some more light for you cause im curious to read all the info
Old Mar 22, 2011 | 07:25 PM
fonkernuckle's Avatar
You can swap over IM,dizz from the 2000 bad engine which also has the crank position sensor on it so either you change oil pumps (put an obd-2 one in the obd-1 block) and then you can put the crank position sensor(cps) on the obd-1 block(they don't utilize one) or do the crankposition sensor trick.also don't forget to change crank gear since the obd-2 one has the gear teeth that the crank position sensor relies on for position if you don't do the trick and use the cps
scarney
Oct 25, 2008 11:43 PM
cactusman
Feb 24, 2007 10:02 AM
Kyoto now
May 10, 2006 07:47 AM
Project99EK
Jan 16, 2004 05:13 AM
