over heating problem
Old Mar 14, 2011 | 11:44 PM
jdm_xsi206's Avatar
Default over heating problem
So I changed the thermostat and radiator but my dc still over heats. The water pump is new there's no leaks that I can see. So what could be the problem???
Old Mar 15, 2011 | 03:52 AM
fcluddington's Avatar
Default Re: over heating problem
what mods have u done.
Old Mar 15, 2011 | 06:00 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ more info.
Starting with MM&Y of car?
What if any mods?
Does rad fan turn on?
Have you actually checked the engine temp. or are you going by cluster temp. gauge?
Have you bled the system properly? 94
Old Mar 15, 2011 | 07:20 AM
jdm_xsi206's Avatar
My bad... so its a 2000 gsr but I have a lsv in it. B18b1 block and b16a2 head. I don't think the fan turns on cuz it started to over heat and nothing. Both top and bottom hoes gets hot. The bottom takes awhile to worm up. I don't know if that's normal. But yeah. I'm thinking its because of the fan. So I switched out the relay for the cooling fan with the ac fan and the fan stayed on so I took it right back off. I didn't bleed it yet. I jus added more coolent to it.
Old Mar 15, 2011 | 09:30 AM
Apathy47's Avatar
Possibly air bubbles in the system then, you need to properly bleed it anytime you add/remove parts from the cooling system.
Old Mar 15, 2011 | 09:49 AM
jdm_xsi206's Avatar
I think I'm about to take it to a shop to have them bleed it for me haha
Old Mar 15, 2011 | 12:11 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Ok well since you know the fan isn't working, fix it!
Why would you take it somewhere to bleed?!?!
Take the rad cap off start the car and let it run til it gets hot, preferably if the fan worked, until the fan kicked on and keep topping it off while its running.
Old Mar 15, 2011 | 03:04 PM
red-dc4's Avatar
when is rhe last time you changed the water pump ? does it get hot when your at a stop or when your rolling . just because it doesnt leak doesnt mean the pump fins arent slipping
Old Mar 15, 2011 | 04:12 PM
fcm's Avatar
fcm
Old Fart
Pretty good bet the pump is not the problem.
As Mattb16teg suggests, fix the rad fan problem.
Start by unplugging the "Rad Fan Switch" and jump the plug, if rad fan turns on, replace the RFS. 94
Old Mar 15, 2011 | 04:49 PM
jdm_xsi206's Avatar
Thanks everyone. I think I might need a new radiator cuz when I start the car and let it warm up all I see is steam or white smoke coming out near the fan. But the thing is I don't see a leak. As for the fan. I kept the car on for about 15 minutes and the fan still never came on. I switch the ac relay with the fan relay and the fan jus stayed on even after the car was off.
Old Mar 15, 2011 | 05:24 PM
Mattb16teg's Avatar
Community Builder
uhh you 100% it's coming from the radiator?
Old Mar 15, 2011 | 06:37 PM
Murk 'EM's Avatar
Go to your local auto zone or parts store and rent a cooling system pressure tester.. Make sure the radiator is full and pump about 15psi into the system if it holds good.. Well kinda.. If not then find out where its leaking from.. Sometimes you can hear it wich really helps.. Good luck..
Also are there any codes alot of times the coolant temp sensor goes out and says your over heating when your really not.. If theres no codes and no leaks get a dvom and test the temp sensor i think theres a thread on here explaining how to test it by resistance
Old Mar 15, 2011 | 09:50 PM
jdm_xsi206's Avatar
I think that's what I'm about to do.
Old Mar 16, 2011 | 03:16 AM
go ahead and pull out the fans and shrouds that way you can look at the rad better. Then you can see the radiator... also look at the very bottom of the radiator. I have had small leaks and they always pool up in a channel in the lower part of radiator.
Old Mar 16, 2011 | 10:09 AM
jdm_xsi206's Avatar
thanks. im about to start woing on it now. so i will keep updates
Old Mar 16, 2011 | 11:31 AM
Chrisdc2's Avatar
I've got the same problem, it over heated while driving on the freeway, then once I came to a stop, it cooled down, I thought it was my fan, but no it isn't because the fan works, no leaks, thermo was replaced a couple months ago, and as for the water pump, I'm hoping it's not that. its stock b18
Old Mar 16, 2011 | 12:14 PM
blown_ss's Avatar
as far as the over heating and the fan not coming on i can almost bet all you need to do is bleed the system. i had the same problem and it was because of air in the system. not sure about the smoke though.
Old Mar 16, 2011 | 12:19 PM
djkobe's Avatar
have you checked all the lines to make sure that they are not clogged? but as people above have stated check the temp sensor to make sure its working properly as well as trace all wiring to the fans to make sure they have good connection
Old Mar 16, 2011 | 12:21 PM
jdm_xsi206's Avatar
Well I turned over my car today to see if my car would over heat and I drove it around for a little. It didn't over heat but when I. Stopped to check under the hood I saw that thr radiator had white smoke come from the bottom. But the thing is I don't see a leak or hear anything. The bottom radiator hoes warms up and has pressure
Old Mar 16, 2011 | 12:24 PM
jdm_xsi206's Avatar
How do you check the temp sensor?
Old Mar 16, 2011 | 12:28 PM
Mattb16teg's Avatar
Community Builder
OHM out the sensor, I don't remember the specs though, Look those up.
I'm really baffled by the smoke but you must have some type of leak, where exactly is it coming from?
You could also try a new radiator cap. When you take off the cap does it sound like unscrewing the top of a soda bottle?
Old Mar 16, 2011 | 12:41 PM
jdm_xsi206's Avatar
Thanks ill try that. I got a new cap about 2 months ago. So I don't think it could be that. I'm thinking of doin a leak down to see if the radiator is bad or not.
Old Mar 16, 2011 | 12:53 PM
Mattb16teg's Avatar
Community Builder
You mean a radiator pressure test?
Yes do that.
And don't ever assume just because something in new that it is "good".
I've had several thermostats and minor things be bad/defective when buying brand new.
Old Mar 16, 2011 | 12:59 PM
jdm_xsi206's Avatar
Yes do that.
Yeah that's what I mean... and yeah your right about new things could go bad. But my hose warms up so I think the new thermostat is good.
Kenneth723
Jun 9, 2019 07:38 PM
levl
Jun 22, 2011 04:53 PM
SFlCrx
12
Sep 25, 2006 06:24 PM
rextec
21
May 17, 2006 05:43 PM
celica26
Dec 29, 2004 08:40 PM
