shiftlinkage
Old Mar 10, 2011 | 11:44 AM
jdm-style-dc2's Avatar
Default shiftlinkage
today i took my carpet out and saw that the shiftlinkage is not bolted right it doesn't even have bolts!. the tranny was replaced not too long ago so i guess they put it back in a rush.
I dont have jack stands yet so i cant see ( from the bottom) if the bolts are different length or one is about to fall off.
My quaestions are:
1. when i order a shiftlinkage fomr honda would it come with bolts and bushings ?
2. could this be the reason why sometimes is hard to go into reverse ? i also heard it could be that my short shifter is to tight.
thanks for your help in advance
Old Mar 10, 2011 | 12:40 PM
mouab18c1's Avatar
Default Re: shiftlinkage
Looks fine to me. Just replace the rubber piece you need.
Old Mar 10, 2011 | 01:35 PM
Im talking about the the two silver screws
Old Mar 10, 2011 | 01:48 PM
mouab18c1's Avatar
I know, that's what I'm referring to. You can add nuts on them to secure them more but it should be fine the way it is. You don't need to buy a whole new shift linkage.
Old Mar 10, 2011 | 08:08 PM
Jimmy's Avatar
Global Moderator
You can grab some new bushings for like $15.00 bucks here. http://www.heeltoeauto.com/home.php?cat=321
Old Mar 10, 2011 | 09:16 PM
Scooooter7's Avatar
The two silver screws are actually the bolts. The nuts are welded to the floor.
Old Mar 11, 2011 | 05:59 AM
fcm's Avatar
fcm
Old Fart
The shift linkage consists of 30 diff. parts, all sold separately, bushing "kits" and so on will also be available... http://acuraautomotiveparts.org/acur...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal 94
Old Mar 11, 2011 | 06:40 AM
Thanks for the good info alot of stuff that I didn't know. The fact that one is longer than the other still bothers me and one is in a angle ( but i feel more safe now knowing that the nuts are welded to shell , i thought it was going to fall off while i was driving) I will try to get matching bolts from home depot as for the bushings which ones are better the ones from passwordjdm.com or those red ones ?
Old Mar 11, 2011 | 07:31 AM
Aight so i dont make another thread can anyone please tell me what should be going in this holes ?....
Old Mar 11, 2011 | 07:49 AM
civicsmoke's Avatar
the first pic the arrow on the right is for tentioning the power steering, mine is a wing bolt, but you can just get a regular bolt to fit there.
Old Mar 11, 2011 | 09:35 AM
i dont understnad how it would work... could the be the reason why my ps broke a couple of months after i installed a new one?
Old Mar 11, 2011 | 05:59 PM
Scooooter7's Avatar
It looks like you are good with a camera, so why don't you take a picture of what you are going to work on before taking anything apart? It might help get it back together right the first time.
I would not replace those shifter bolts with just any grade bolt. Home Depot would not be the place to purchase automotive grade bolts.
Old Mar 12, 2011 | 07:29 AM
i havent taken anything apart yet. the owner before me did i guess Im just trying to get everything right.
Good point about the bolts im going to contact the dealership first.
ej8ster96
Jan 4, 2011 03:31 PM
denniscoles
May 3, 2007 10:43 PM
Hatchorama
Sep 8, 2006 02:07 PM
JerkzEm1
May 16, 2005 06:34 PM
Hcivic88
Aug 11, 2004 08:48 PM
