ABS sensor replacement
Old Mar 9, 2011 | 07:15 AM
BAY_99DB8LUV's Avatar
Icon2 ABS sensor replacement
I need to replace my rear ABS sensor that I broke while swapping out my LCA,
Question is should I ether try to splice & repair the wire. Replace it with a used one. Or get one from autozone or o'rielys ???
Old Mar 9, 2011 | 11:17 AM
mark@silbernage's Avatar
Default Re: ABS sensor replacement
I suppose it depends upon your skills with a soldering gun? If you're up to it and can shrink-wrap and weather seal when you're done I'd try repair (if it were mine). If you don't do well, you'll just get a code from the ABS computer complaining about the signal, right?
; ' ) Mark
murphmatic
Honda Civic (2001 - 2005)
Aug 27, 2014 02:09 PM
chazt
Honda CR-V & Element
Apr 16, 2013 01:04 PM
rollercosta123
Nov 25, 2005 12:09 AM
