trans problem?
Old Mar 14, 2011 | 06:02 PM
Aqualite_Solid's Avatar
Default trans problem?
I had the axels replaced on my LS n i was driviing home and it started grinding and i pull i a lot on a slight hill n i didnt have the power to pull in. I put it in park and its a grind an sqeal.its grinds in 1-4 and doesnt move but i have reverse. I pull out passenger axel n trans fluied leaks out. Tires will spin with front front jacked up. This trans has NEVER had any sighs of bein bad. So im stumped and yes its an auto
Old Mar 14, 2011 | 08:58 PM
mouab18c1's Avatar
Default Re: trans problem?
Trace back to see if everything is installed properly.
Old Mar 14, 2011 | 11:05 PM
cracker1252's Avatar
was it possible the axle was not in all the way?
Old Mar 15, 2011 | 05:13 AM
Axles are in good i took em out and put em back in.but wat confuses mr reverse is perfect. If the axles wernt in correctly reverse wouldnt be so smooth.torque converter maybe? But 3 months ago it was a problem with my gear selector being stuck in park.
Old Mar 15, 2011 | 01:33 PM
sorry man. but sounds like you might needs a new trans. again check the cable linkage make sure its not caught up on anything like the exhaust. otherwise, im sorry i am out of ideas. good luck
Old Mar 16, 2011 | 05:56 AM
Thanx man i belive its died also
Old Mar 16, 2011 | 06:03 AM
rash's Avatar
I'm pretty positive that trans fluid leaking out is normal when you pull the passenger side axle. At least on manual transmissions they are...
What it sounds like is you're out of tranny fluid. Check the level. You have to refill the tranny after changing the passenger side axle!
Civic HX 121
Transmission & Drivetrain
Dec 6, 2013 06:24 PM
kodylive
Sep 17, 2012 08:53 PM
incredteg3
Apr 2, 2008 06:16 PM
JDMPheens
Apr 13, 2006 03:32 AM
96integraLS
Acura TL, RL & ZDX
23
May 30, 2005 04:19 PM
