Da9 suspension help
1 Post
Re: Da9 suspension help
So you want to know if the Skunk adjustable ball joints (CAMBER KITS) will fit the Ebay camber kits.??
Why would you want to install a camber kit on a camber kit?
That means remove the original ball joint the ebay kit comes with and replace it with skunk 2 ball joints, you get what I mean?
1 Post
No it wont work.
The skunk ball joint is made to work with the stock control arm and slide on its own mount seen here http://cgi.ebay.com/ebaymotors/SPECI...0608448084,the Not the skunk but looks just like it.
Ebay control arm kits are set up to slide on its own control arm as seen here http://cgi.ebay.com/ebaymotors/90-91...Q5fAccessories.
1 Post
Now if this is what you're looking to get,it still wont work.
http://cgi.ebay.com/ebaymotors/SKUNK...item3365649380
russianswty
03-09-2007 10:26 PM
slipstream
08-16-2005 01:56 AM
