help spring rates
Old Mar 9, 2011 | 12:28 PM
jefftron's Avatar
Default help spring rates
Will delsol front springs be the same as da front springs. Would they be interchangeable?
Old Mar 9, 2011 | 12:59 PM
MD426's Avatar
Default Re: help spring rates
Not entirely, Del Sols are lighter and there for different rates. Find a cheap set or just looking for new springs?
Old Mar 9, 2011 | 07:44 PM
jefftron's Avatar
No my cowork has a set of skunk2 coilovers On his da, but he's getting rid of them cuz he doesn't like it lowered. He already has a set of stock springs in the rear. So i was thinking since the rear spring rate should be higher than the from, maybe i could give him the rear springs off my delsol for the front on his da and it would be alot closer spring rates than the fronts off my delsol.
Old Mar 9, 2011 | 07:52 PM
MD426's Avatar
Front springs usually have higher spring rates because the front end is heavier due to the engine+driver. They should be around the same but I'm sure it wont be to the OEM springs integras have.
Naturally Aspirated
Sep 21, 2004 06:23 PM
BABY NSX
Sep 4, 2003 07:42 PM
ALF
Oct 25, 2001 11:16 PM
