injector question
Old Mar 19, 2011 | 03:01 PM
masonracing's Avatar
Default injector question
my buddy gave me some dsm 275cc injectors. i was wondering what i needed to install them. i have a built b18c an figured the extra cc's wouldnt hurt. or should i just run stock injectors?
Old Mar 19, 2011 | 06:11 PM
mouab18c1's Avatar
Default Re: injector question
Are you breaking 200 whp? If not then you don't need them.
Old Mar 19, 2011 | 06:20 PM
B18c ls crank/rods. P30 pistons. .020over. Skunk2 pro series vavletrain. Mild port. Its going on dyno to tune next month. Highly doubt 200 whp. So I should stick with stock?
Old Mar 19, 2011 | 07:22 PM
mouab18c1's Avatar
What cams?
Old Mar 19, 2011 | 07:24 PM
pro 1s
Old Mar 19, 2011 | 08:15 PM
mouab18c1's Avatar
Then yea! I would upgrade from the stock 240cc injectors. What obd are you?
Old Mar 19, 2011 | 08:20 PM
obd2 with jumper to obd1 ecu. will these injectors work?
Old Mar 19, 2011 | 08:40 PM
mouab18c1's Avatar
You will need to change out the injector clips. But they will work. You might need a resistor box for those injectors. Do research on it.
LS_VTECteggy
Aug 28, 2011 09:17 PM
swt_666
May 16, 2007 09:33 PM
whp
Nov 9, 2004 06:31 AM
SpoolnG2
May 18, 2004 12:33 PM
