crower cams
Old Mar 24, 2004 | 05:19 PM
98-ls's Avatar
Default crower cams
i looked up crower cams and the 404's say they reqire an ecu mod does any one know what this is
Old Mar 24, 2004 | 05:20 PM
Kendall's Avatar
Default Re: crower cams (98-ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-ls &raquo;</TD></TR><TR><TD CLASS="quote">i looked up crower cams and the 404's say they reqire an ecu mod does any one know what this is</TD></TR></TABLE>
Lots of people know what an ECU mod is. And if you used the search feature, you could know too.
Old Mar 24, 2004 | 05:24 PM
98-ls's Avatar
Default Re: crower cams (Kendall)
i know what it is what i really want to know is if i need it
Old Mar 24, 2004 | 05:26 PM
Kendall's Avatar
The Crower 404's are pretty crazy. I wouldn't run them without a fully built engine, very high compression and some form of programmable engine managment (the ecu mod) such as AEM or Hondata. Hell, I wouldn't even run the 402's without at least PR3 pistons.
Old Mar 24, 2004 | 06:27 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-ls &raquo;</TD></TR><TR><TD CLASS="quote">i know what it is what i really want to know is if i need it</TD></TR></TABLE>
yes you need it.
the cams are pretty wild. and without the proper ECU tuning it wont run very well and you probably wont see very good gains.
Old Mar 25, 2004 | 11:07 AM
zilverz's Avatar
I emailed Crower about what feature modification they were refferencing with the ECU mod. IF it was just to fix redline or what. But they never replied to me .
Also, I wouldnt tell everyone to put way high compression with 404z and leave it at that. High compression + 404 = mega close clearance issues with the valves. It isnt recommened to advance the cam gears past 1 degree.. If you have 10.5+Compression + 404s it is probably a good idea to take your ITR,CTR, Forged piston to the machine shop and have them grind the valve relief down further. Just to be on the safe side. You never know what some jackass on the dyno might advance your cam timing too far .. and tell you "sorry"
jennsGSR
Jul 23, 2006 11:33 AM
camlob
46
May 15, 2006 04:46 PM
killablaze
Oct 12, 2005 12:52 AM
hb4u2nv
Jun 17, 2004 10:28 PM
k0reanrenegade
Jan 26, 2004 02:45 PM
