hatch doesnt work
Old Mar 24, 2004 | 06:11 AM
B18CR-X's Avatar
Default hatch doesnt work
my hatch stop working after i reset my maintance light, ican hear my motor working but it wont open can anyone help me out. thanks
Modified by B16SI00 at 8:28 AM 3/24/2004
Old Mar 24, 2004 | 06:21 AM
Creep's Avatar
Default Re: hatch doesnt work (B16SI00)
huh?
Old Mar 24, 2004 | 07:17 AM
B18CR-X's Avatar
bump
Old Mar 24, 2004 | 07:22 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
hatch? motor? what?
Old Mar 24, 2004 | 07:47 AM
B18CR-X's Avatar
yeah my hatch wont open anymore
Old Mar 24, 2004 | 07:51 AM
StolenTeg's Avatar
Default Re: (B16SI00)
Sunroof???
Old Mar 24, 2004 | 08:23 AM
B18CR-X's Avatar
my rear hatch does not work whats wrong
Old Mar 24, 2004 | 08:29 AM
Audi A4's Avatar
DUDE... elaborate more... what do u mean?
Old Mar 24, 2004 | 09:08 AM
B18CR-X's Avatar
i try to move the switch in the rear hatch but it wont do anything
Old Mar 24, 2004 | 09:14 AM
Community Builder
there is no motor associated w/ the hatch lid... what switch are you talking about, the hatch release lever by the gas door lever by the driver side?
Old Mar 24, 2004 | 09:15 AM
Audi A4's Avatar
Default Re: (PatrickGSR94)
omg... wtf are you talking about man.. take the time to explain...
Old Mar 24, 2004 | 09:17 AM
B18CR-X's Avatar
ok how do you guys open your rear hatch from were
Old Mar 24, 2004 | 09:21 AM
StolenTeg's Avatar
First off what years of teg are you talking about, 94-97 you have to pull a thing. like how you open your gas tank. For 98-01 hatch unlock the door, do back put your finger in feel the switch and move it to left or right i forgot . cant belive i forget when i do it everything .
Old Mar 24, 2004 | 09:29 AM
B18CR-X's Avatar
i have a 2000 teg and my switch is in the back, it lock and unlock but it just wont open i can hear a motor moving when i try to open it, this all started when i reseted my maintnance light by pushing the switch under the steering column.
Old Mar 24, 2004 | 09:30 AM
Audi A4's Avatar
Default Re: (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote"> . cant belive i forget when i do it everything .</TD></TR></TABLE>
huh
Old Mar 24, 2004 | 09:32 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16SI00 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2000 teg and my switch is in the back, it lock and unlock but it just wont open i can hear a motor moving when i try to open it, this all started when i reseted my maintnance light by pushing the switch under the steering column. </TD></TR></TABLE>
Perhaps there is an actuator on the rear latch that works w/ keyless entry or something on the 98+ Integras, I dunno... but I assure you the maintenance light reset button could not possibly have anything to do with it, it's just a wierd coincodence.
Old Mar 24, 2004 | 09:34 AM
phatintegra0734's Avatar
there is definitely no link between resetting your maintenance light and your hatch not opening
Old Mar 24, 2004 | 09:36 AM
B18CR-X's Avatar
when someone is pushing the button under the steering column i move the switch on my hatch it does open it i dont know why
Old Mar 24, 2004 | 11:31 AM
Nfurno's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Perhaps there is an actuator on the rear latch that works w/ keyless entry or something on the 98+ Integras, I dunno... but I assure you the maintenance light reset button could not possibly have anything to do with it, it's just a wierd coincodence.</TD></TR></TABLE>
It sounds likes the actuator like patrick said. I was told by acura that it is common for those things to go out.
Old Mar 24, 2004 | 01:55 PM
B18CR-X's Avatar
ok thanks for the help
Old Mar 24, 2004 | 02:06 PM
99IntegraGS's Avatar
Default Re: (Nfurno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nfurno &raquo;</TD></TR><TR><TD CLASS="quote">It sounds likes the actuator like patrick said. I was told by acura that it is common for those things to go out.</TD></TR></TABLE>
My '99 Integra hatch will only open with the key. The lever won't open the hatch for me. I wish someone could tell me how to fix it... don't feel like paying Acura to do it.
Old Mar 24, 2004 | 02:09 PM
cougar10ag's Avatar
wait so 98+ tegs lock and unlock the hatch along with the doors? theres no unlock lever?
Old Mar 24, 2004 | 02:18 PM
Community Builder
Default Re: (cougar10ag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cougar10ag &raquo;</TD></TR><TR><TD CLASS="quote">wait so 98+ tegs lock and unlock the hatch along with the doors? theres no unlock lever?</TD></TR></TABLE>
Instead of a lever inside by the gas door release, the 98+ has a release under the edge of the hatch itself. I'm guessing from what has been said here that it also has an actuator like the door handles for remote trunk release function.
Old Mar 24, 2004 | 09:16 PM
On my '99, if I turn the key in the door lock and hold it for a second or so, I hear the other locks open. At this point I should be able to use the lever inside the hatch handle to open the hatch. I cannot.
I'm pretty sure I hear the lock in the rear make noise, so I think it's trying to unlock, but just isn't.
Sigh...
JD
Old Mar 24, 2004 | 10:53 PM
IntegraLova's Avatar
Default Re: (99IntegraGS)
my 99 teg's hatch wont open sometimes. The switch will just get stuck sometimes and the hatch wont budge.I just hit the unlock and lock button a few times back and forth on my keyless entry and that does the trick for me anyway.
