Tranny problems
Old Mar 26, 2004 | 12:03 PM
G2IC_LOVER's Avatar
Default Tranny problems
Hello guys I have a 94 teg with tranny problems.. I just got the car and found that when I put it in drive it jurked and the shifts while driving where not too smooth.. I changed the tranny oil and the shifts while driving got much better, but the final sown shift is not very smooth and the parking and to drive shift is still jurkey but not as much... Think my tranny is gone or what.... thanks in advance...
Old Mar 26, 2004 | 12:31 PM
MightyMouseTech's Avatar
Default Re: Tranny problems (G2IC_LOVER)
Try changing the fluid four more times. When you drain the fluid in a Honda auto, you only get about 1/4 of the fluid out. To do a full flush, you have to drain/fill/drive four times. It's a pain in the ***, but that is what is says to do in the factory manual. But this is only for severe cases. Usually you just drain and fill.
I have seen this make a world of difference on cars where it hasn't been done in a LONG time.
Old Mar 26, 2004 | 12:49 PM
Chris's Avatar
Default Re: Tranny problems (MightyMouseTech)
also, make sure you idle is set properly.. if the car is revving too high when you put it in gear, it will jerk
Old Mar 26, 2004 | 01:11 PM
projectTeG's Avatar
i got a tranny for sale if u need one...but gl
Old Mar 26, 2004 | 02:01 PM
G2IC_LOVER's Avatar
Default Re: (projectTeG)
thanks for the advice I will change the oil a couple of times, hpoefuly it works.. I am in canada so to dhip a tranny from the states will be costly, if that is what i need ..
Old Mar 26, 2004 | 02:09 PM
Solipsist's Avatar
I just found out after runing a track event yesterday that my main shaft bearing is going out. great...
PROS = can be replaced with a type r tranny w/ LSD
CONS = I was qouted this morning $3000+ with parts & labor.
Old Mar 26, 2004 | 02:13 PM
Brian_TII's Avatar
Honda automatic trannies aren't exactly known for their smoothness....
Old Mar 26, 2004 | 02:16 PM
G2IC_LOVER's Avatar
Default Re: Tranny problems (Brian_TII)
Brian>>>> you think what I am experiencing with my teg is normal.... Caz I have a 99 civic and it shifts smoother, I know its a newer car, but still. I am most worried about the jerky shifts from park to drive and reverce..
Choppin
Mar 28, 2011 09:35 AM
ragnarok0mega
Aug 1, 2010 06:32 AM
ill phil
15
Sep 4, 2002 10:37 PM
Kazmans94cord
Apr 11, 2002 01:34 PM
