dizzy help PLEASE!!!???
Old Mar 25, 2004 | 09:31 PM
95gsrturbo's Avatar
Default dizzy help PLEASE!!!???
so im driving down the road and car starts to run rough (2mins in to the drive) so i pull into mickey D's
before i can pull into a spot the car shuts off leaving me to puch it into a spot--
pop the hood and woa looky here-- one of theplug wires has come off the distributer.. no prob-- pop it back on--
still no start....
so i open the cap and check the rotor-- i have had the rotor button fly off before at high rpms and get crushed-- several times even with lock tite on the dang screw....
so sure enough the screw is a bit loose-- i tighten it up
still no start.. buy a new rotor button (had to WALK two blocks --lol) new button = no dice
car turns over like it wants to start but nothing happens--
any suggestions?? its late now and i have a test tomorrow so i said forget it.... ill check to see if each wire has spark and this will tell me if the dizzy is bad but any other suggestions??????
Old Mar 26, 2004 | 01:00 AM
King_j's Avatar
Default Re: dizzy help PLEASE!!!??? (95gsrturbo)
test to see if you have spark.
if no spark, then check main relay, check to see if you hear the fuel pump prime, if it none of these its most likely the ignitor. the ignitor is behind the rotor, it has 3 wires comming off of it.
search and you will find detailed explanations of all of this.
good luck
Old Mar 26, 2004 | 08:44 AM
95gsrturbo's Avatar
Default Re: dizzy help PLEASE!!!??? (King_j)
thanks
im gonna check for spark tonite...
let you know then--
95gsrturbo
Mar 11, 2014 04:15 AM
k2kyl
Jul 16, 2010 07:16 PM
S2KILLA
Nov 29, 2006 06:00 AM
sohc90rex
16
Dec 21, 2005 09:20 PM
95gsrturbo
Mar 27, 2004 12:15 AM
