Caliper Bolt Question
I needed a certain bolt replaced on my passenger side caliper that I ordered from Honda and I don't think I got the right one. I'm at work and I'm wanting to know if it's the right one before I leave work this evening. It's the bolt that holds the caliper to the caliper mounting bracket. There are two of them.. top and bottom. They bolt up where it has the rubber banjo looking sleeve. The bolt I got is a Honda genuine bolt 45240-S01-A01. IS this the right one? Can anyone link a picture of the right one?
Yep that's not the bolt that has the rubber boot on it. What you got there is #14 in this pic, what you need is #12 and #17:
OK so I have the right bolt that is going to hold the top of the caliper to the mounting bracket right? I don't need the bolt that holds the mounting bracket to the rotor assembly. The bolt that I need does bolt right up to that rubber sleeve though. I'm assuming the bolt doesn't go all the way through it though? I'll know once I get home when I can see it of course. I was just wanting to know now. Thanks for the input guys.. keep'em comin.
The correct part number is 45240-SA7-003 with description BOLT, FLANGE (8x22). 4 required for left and right calipers for the front.
Keep in mind these bolts attach to a sliding pin. Upper Pin is 45262-SR3-N31 and lower pin is 45235-SR3-N31.
Len
Len
