window!
Old Mar 25, 2004 | 08:26 AM
1995silverinteg's Avatar
Default window!
i have a 95 ls and ive been having problems with my window,it wont go up al the way, and everytime i put it down and then put it back up it gets more of a gap, at first it was a quarter inch now its like an inch, i try to put it up all the way and it just clicks,can anyone help?
Old Mar 25, 2004 | 08:30 AM
spark plugs.
Guest
Posts: n/a
Default Re: window! (1995silverinteg)
the window slipped off the track, you're gonna hafta open the door up, and put it back into the track. i've had the same problem...i'm pretty sure of this.
Old Mar 25, 2004 | 08:36 AM
Zunger's Avatar
try and use your fingers to lift it up all the way. If it goes up, then yes, its off the track. If not, then you might have a rock/alot of dirt bilt up blocking it from going up. Ive had the rock problems a few times on my other vehicles.
Old Mar 25, 2004 | 08:38 AM
Default Re: window! (Zunger)
yeah its like an inch down, but when it rains or whatever i have to lift it up and it usually stays up but sometimes it just falls back down
Old Mar 25, 2004 | 08:55 AM
zuhaetler's Avatar
Take the door apart. There is a little rubber rail thing that's probably fallen off. You need to stick it back on and lube the track. That or the power window motor is dying for some reason but I haven't heard of anyone with that problem.
Old Mar 25, 2004 | 12:09 PM
Default Re: window! (zuhaetler)
what am i gonna lube the track with?anything really, ami gonna need any tools to take a part the door to get to the window?
Old Mar 26, 2004 | 05:09 AM
zuhaetler's Avatar
Yes you have to take apart the door and all you need are some screwdrivers. The track is lubed with compressor oil.
inaety
Nov 3, 2009 08:20 PM
g0tgot
Nov 18, 2007 10:00 AM
EJ8 GSR-T
12
Aug 4, 2007 11:07 AM
mehron
Jan 10, 2007 11:23 AM
n3v3tz
Feb 5, 2004 12:07 PM
