Help on installing a Tranny.
I plan on installing a tranny on my gsr engine. But I was wondering what gaskets and seals will I need to do this? Part Number etc. HELP
do u know how much miles is it? did u know that the one u r going to put in is not grinding? But I suggest get synthetic oil with when u put it together.
If there is no grinding or anything wrong with it, there is no need to open it up. There are only 2 seals you need to worry about they are the oil seals/axle seals. 2 on each side. Not very expensive and easy to replace provided you have the tranny opened up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTOKOTO-TSOI »</TD></TR><TR><TD CLASS="quote">do u know how much miles is it? did u know that the one u r going to put in is not grinding? But I suggest get synthetic oil with when u put it together.
synthetic oil
no-no for a transmission
Honda MTF
GM or Pennzoil Synchromesh
</TD></TR></TABLE>synthetic oil
no-no for a transmissionHonda MTF
ive had good results with redline mtl - it's synthetic oil with friction modifier. but in general yes, synthetic is bad... too slippery for them synchro bishes.
