Help, speedometer is going crazy!
Old Mar 26, 2004 | 03:20 AM
sleepin91teg's Avatar
Default Help, speedometer is going crazy!
Today, i took out my guage cluster in my 1991 integra LS...and after putting it back in, when i took it out for a spin, the speedometer, doesnt read, it just rapidly shoots from one speed to the other, in a ticking motion, back forth back forth back forth and so on. and its really really fast, what did i do wrong? speedo cable not in the cluster right or what? Please help, need this done so i can drive it this spring!
Thanx
Old Mar 26, 2004 | 05:16 AM
Creep's Avatar
Default Re: Help, speedometer is going crazy! (sleepin91teg)
Are you sure you plugged it in all the way and its
seated correctly.
Old Mar 26, 2004 | 06:55 AM
Arsenal's Avatar
Default Re: Help, speedometer is going crazy! (Creep)
Sounds like you have a short somewhere, my tach did the exact same thing, found a bare wire in the engine bay which would touch the chassis when driving.
Double check the wires in the cluster, you might have them reveresed.
afterdark
13
Apr 30, 2009 10:12 AM
burgandybeast
Nov 2, 2007 02:30 PM
nomoreavril
10
Dec 11, 2006 04:02 PM
Built B18ABorC
Oct 26, 2004 05:41 PM
