Need HID help, PLEASE!
Old Mar 27, 2004 | 10:47 PM
r0c5t4r's Avatar
Default Need HID help, PLEASE!
Alright I am using the Bosche HID ballasts using Phillips 4100K bulbs. For some reason one of lights aren't working. I plugged the bulb in to the other ballasts that was working and worked fine. Is there something wrong with the ballast, It was working fine then started to blink and then it just shut off. Is there a way I can fix it? Should I open up the ballast?
Old Mar 27, 2004 | 11:02 PM
96 Ls lnTeG's Avatar
Default Re: Need HID help, PLEASE! (dfunkd)
check you grounds...
Old Mar 27, 2004 | 11:51 PM
civicbro's Avatar
Default Re: Need HID help, PLEASE! (96 Ls lnTeG)
hit up hidforum.com for all your hid questions. People on that board are really helpful with hid problems.
Old Mar 28, 2004 | 03:21 AM
B18GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Ls lnTeG &raquo;</TD></TR><TR><TD CLASS="quote">check you grounds... </TD></TR></TABLE>
I would also suggest this. When I put in my HID's, I had no idea what I was doing since I didn't know what grounding meant. Until I grounded all the wires, it worked perfectly.
Also, since you said the bulb blinked and then turned off, maybe it blew. Hopefully this didn't happen or else you'd be spending quite a few dollars for a new one..
malubawla
Aug 10, 2006 07:42 PM
nyrican23
Jul 6, 2006 08:01 PM
CrazyModGSR
Apr 29, 2004 07:57 PM
shift6th
Honda S2000
Apr 13, 2004 03:49 AM
UltimX
Oct 23, 2003 11:57 AM
