V-Tec???
Old Mar 26, 2004 | 05:59 AM
mini-v-si's Avatar
Default V-Tec???
I did a conversion from obd2 to obd1, at first my vtec engaged at around 4500 rpm with the skunk 2 chip, now it engage at 5500, anyone know what happen???
my mods:
Dc header/exhaust
skunk 2 cam
skunk 2 cam gear
68 mm holley tb
aem cold air
Old Mar 26, 2004 | 06:35 AM
SuzukaBlueAP2's Avatar
Default Re: V-Tec??? (hx007)
well, if you did that conversion, you changed ECUs, which could have alternate VTEC engagement points. That would do it.
Old Mar 26, 2004 | 07:08 AM
xSCTYGx's Avatar
what ECU did u use?
Old Mar 26, 2004 | 07:21 AM
631 Teggy's Avatar
Default Re: V-Tec??? (2Gen91Teg)
LOL... Different chips use different vtec engagement points...
Is it a GSR? Cuz if you are running the stock intake manifold it could be that the secondaries just aren't opening up, so it SOUNDS different to you. Other then the obd1 gsr ecu, no other obd1 ecu's manage the secondaries. So that could be it too.
Old Mar 28, 2004 | 06:39 PM
mini-v-si's Avatar
sorry for not being cleared on the question. I had the same setup but recently my distributor fell off, timing was off, so now go everything together but v-tec engaged at 5000-5500 rpm. what could cause that to hit high now???
vtecn8ive
Engine Management and Tuning
Jun 21, 2010 10:43 PM
vtizzle
Apr 23, 2009 12:04 AM
sway892
Aug 21, 2008 08:42 PM
ridestrt
Jan 20, 2004 12:18 PM
deez nuts
Mar 12, 2003 11:07 AM
