Help!: How to Take Header Off
Old Mar 27, 2004 | 02:31 PM
ChadTeg's Avatar
Default Help!: How to Take Header Off
hey guys
i just got a nice header for my G3 Teg and ive found out that my header is rust and the bolts are very rust too.
Ive too all the bolts out of the old header but the last one pissed me off.. u know the oxyzen breathe tube, its SO TIGHT!! my friends and i tried to use wrench to take it off and it was useless,
we tried to unplug the the tube, no luck either
so anyone who knows or experienced how to unplug the tube or take the oxyzen tube off ? Please help me how to do it asap
thank you for your time and attention to the message
Chad
Old Mar 27, 2004 | 02:39 PM
driftersillusions's Avatar
Default Re: Help!: How to Take Header Off (ChadTeg)
its all about muscle and wd40
Old Mar 27, 2004 | 04:25 PM
tilt's Avatar
more leverage. use a decent length breaker bar or slap on a cheater bar if you must
Old Mar 27, 2004 | 04:58 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChadTeg &raquo;</TD></TR><TR><TD CLASS="quote">hey guys
Chad
its Oxygen first of all.. and its the oxygen Sensor that your referring to..i took my rachet and put a long pipe on the end of it..and quickly enough it broke the seal and the o2 sensor unscrewed right off with a breeze
Old Mar 27, 2004 | 05:24 PM
MR. MIYAGI's Avatar
we used wd40 and a mallet!!! that works really good when u dont have an air gun!!!
Old Mar 27, 2004 | 06:50 PM
xplanetearth420x's Avatar
Default Re: Help!: How to Take Header Off (229motorsports)
wd40 and a bar
Old Mar 27, 2004 | 07:27 PM
Tweakmeister's Avatar
wd-40 doesn't do the trick all the time
get some PB Blaster
Old Mar 27, 2004 | 08:55 PM
ChadTeg's Avatar
hey guys
thanks for all ur posts and greatly appreciated, i'll try to use them this week to see if its works, will let u guys know asap , thanks again
keep in touch
chad
Old Mar 28, 2004 | 06:39 PM
IVI's Avatar
IVI
Default Re: (ChadTeg)
there is a little button you have to hold to unplug the harness. get a rotary tool and cut the botls off to get the headers out. use a wrench or even better a special tool for gettin oxygen sensors out. put a big breaker bar over the top. its not that difficult. it might be easier to do when the car / pipe is hot. just be careful not to burn yoruself.
Old Mar 28, 2004 | 06:40 PM
Kendall's Avatar
for PB Blaster over WD-40.
Old Mar 28, 2004 | 06:42 PM
xSCTYGx's Avatar
Default Re: Help!: How to Take Header Off (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">get some PB Blaster</TD></TR></TABLE>
that and a big *** breaker bar should do the trick.
Old Mar 28, 2004 | 08:18 PM
deepgreengsr's Avatar
Default Re: Help!: How to Take Header Off (2Gen91Teg)
No one said HEAT yet? just take a torch to it and it will loosen up.
Old Mar 29, 2004 | 11:32 AM
IVI's Avatar
IVI
Default Re: Help!: How to Take Header Off (deepgreengsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepgreengsr &raquo;</TD></TR><TR><TD CLASS="quote">No one said HEAT yet? just take a torch to it and it will loosen up.</TD></TR></TABLE>
i said start the car for a bit, the heat from the engine is the same thing as putting a torch to it but safer. you dont want to melt the wires off the sensor.
Old Mar 29, 2004 | 11:39 AM
genetsang's Avatar
a decent vise grip and LOTs of anger gets it off with a quickness
Old Mar 29, 2004 | 11:51 AM
penney's Avatar
Default Re: (genetsang)
spray that bastard with penetrating oil and let it do its thing...should be a breeze
Old Mar 29, 2004 | 12:04 PM
gapsook's Avatar
Default Re: Help!: How to Take Header Off (xplanetearth420x)
Spray wd40 and let it soak.
Old Mar 29, 2004 | 01:30 PM
Default Re: Help!: How to Take Header Off (gapsook)
gator grip!!jk that **** is a piece
Old Mar 29, 2004 | 01:37 PM
billybong91DA's Avatar
brake fluid is the best lubricant!!!!!!!
Old Mar 29, 2004 | 03:16 PM
IVI's Avatar
IVI
Default Re: (billybong91DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billybong91DA &raquo;</TD></TR><TR><TD CLASS="quote">brake fluid is the best lubricant!!!!!!!</TD></TR></TABLE> put it in your motor then.
Old Mar 29, 2004 | 03:50 PM
Redtail's Avatar
Default Re: (IVI)
If you just run the engine the sensor will get hot and expand along with the manifold i.e. useless. If you want to use heat take a torch to the manifold around the outside of the O2 sensor but try not the heat the sensor much. As others have said though PB and a breaker bar should be enough.
Good luck
Old Mar 29, 2004 | 04:02 PM
631 Teggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">wd-40 doesn't do the trick all the time
get some PB Blaster
This **** is oldschool domestic! It rawks!!!
Old Mar 30, 2004 | 02:42 AM
WhoisDan's Avatar
PB spray works wonders. I used it when I took off my header.
MajinB
Honda Civic (2001 - 2005)
Apr 20, 2006 03:53 PM
ckyskater733
Jun 15, 2005 02:45 PM
bardo
Jul 27, 2004 06:44 AM
Project_ED8
Mar 10, 2004 11:36 AM
