MTF Question.
Old Mar 26, 2004 | 10:40 PM
5spdIntegra's Avatar
Default MTF Question.
Ok I just bought some Pennzoil syncromesh off the internet. I was planning on changing it tommarow when I read somewhere that Integra's take 2.3 quarts. I only bought 2 quarts!
So do you guys buy 3 quarts to get that extra .3 of a quart in or do you just settle for 2 quarts?
Old Mar 26, 2004 | 10:49 PM
dannylDAsport's Avatar
Default Re: MTF Question. (5spdIntegra)
i fill till its spills over
Old Mar 27, 2004 | 12:54 AM
Deluzional's Avatar
Default Re: MTF Question. (dannylDAsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannylDAsport &raquo;</TD></TR><TR><TD CLASS="quote">i fill till its spills over</TD></TR></TABLE>
I picked up 3 bottles when I last did my transmission fluid, I guess you gotta order another bottle
Old Mar 27, 2004 | 01:52 AM
DC2*Integra's Avatar
Old Mar 27, 2004 | 07:45 AM
Default Re: MTF Question. (DC2*Integra)
How much dose it usually take to spill over?
Old Mar 27, 2004 | 08:14 AM
au-gsr's Avatar
you already answered your own question, refills are 2.3 quarts. a full tranny drain, which can only be done off the car will require slightly more.
Old Mar 27, 2004 | 08:21 AM
zad5's Avatar
your going to need 3 bottles
Old Mar 27, 2004 | 08:37 AM
FastSS's Avatar
Default Re: (zad5)
every time I fill a tranny it takes about 2.1qts...
Yea I always totally drain it, then take the fill bolt and VSS off, and fill through the VSS hole untill it spills out of the fill bolt hole... its full at that point
Old Mar 27, 2004 | 10:26 AM
Default Re: (FastSS)
Thanks guys. I just went and bought another quart.
Old Mar 27, 2004 | 02:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (5spdIntegra)
Remember to make sure the car is level when you fill the tranny, either sitting on the ground or up on 4 jackstands. If you fill it w/ only the front end jacked up, you will get an incorrect reading when the fluid starts spilling out the fill hole because the fill hole is towards the back of the tranny housing, and if only the front end is up in the air it will start spilling out early (tranny will be underfilled). Just a heads-up.
Old Mar 29, 2004 | 08:52 PM
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Remember to make sure the car is level when you fill the tranny, either sitting on the ground or up on 4 jackstands. If you fill it w/ only the front end jacked up, you will get an incorrect reading when the fluid starts spilling out the fill hole because the fill hole is towards the back of the tranny housing, and if only the front end is up in the air it will start spilling out early (tranny will be underfilled). Just a heads-up.</TD></TR></TABLE>
Thanks for the heads up! Everything went fine besides spilling old fluid everywhere.
I wrote a DIY on my website for it: http://auto.snowsuperstars.com/mtf.html.
I hope this will help some people out.
rodvang
10
Jan 19, 2006 09:19 PM
mmmsushi
Oct 23, 2005 09:37 AM
builthatch
Aug 17, 2005 05:37 AM
Circuit Star-29
Jun 2, 2005 03:07 PM
skribblah
Sep 9, 2003 08:05 PM
