door panel
Old Mar 25, 2004 | 01:53 PM
inty2511's Avatar
Default door panel
i put in front speakers and now whenever i close my door hard the door panel comes off. the plastic clips that snaps in snaps out whenever i close the door hard, anybody had this problem and found a fix. only other thing i could think of is replace the plastic clips
Old Mar 25, 2004 | 01:55 PM
Audi A4's Avatar
Default Re: door panel (inty2511)
hmmm did u braek any of them?
Old Mar 25, 2004 | 01:56 PM
Chris's Avatar
Default Re: door panel (DRAG lll INTEGRA)
also.. there is a screw, or two
Old Mar 25, 2004 | 02:00 PM
AllMotorGSR94's Avatar
theres 3 screws. two metal and one that a plastic screw.
the two metal ones are behind the door lever and in the lil i guess side pocket of the door.
the plastic pop peice is where the door meets the dash.
the rest or just snap ins
check all those out and make sure their there
Old Mar 25, 2004 | 02:57 PM
integraL's Avatar
your door panel shoudln't come off unless it's broken or isn't attached right
Old Mar 25, 2004 | 05:11 PM
95LSB18's Avatar
Default Re: (integraL)
U have to make sure attached right. Its kind of tricky.
Just go here
http://www.team-integra.net/se...D=591
Old Mar 25, 2004 | 05:27 PM
98-ls's Avatar
Default Re: (95LSB18)
you can take off the speaker gaurd instead of taking off the hole panel, (for next time) if you cant fix it with zip ties, super glue, or duct tape
suhteevin
Jan 6, 2009 09:04 PM
Hyard24
Audio / Security / Video
Jan 16, 2008 08:12 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
Wildcat1016
Aug 9, 2002 10:38 AM
snake01
Jan 11, 2002 09:06 PM
