Light Flickering
Old Jun 21, 2005 | 10:14 AM
FULL-REV's Avatar
Default Light Flickering
I have a prob wih my low beam lights... they just flikker out of nowhere for no aparent reason... I have HID's and they aren't even over a year old. Does anyone know whats going on?
Old Jun 21, 2005 | 10:32 AM
JDM-EJ1's Avatar
Default Re: Light Flickering (hondaevo)
Maybe a bad ground? Lack of power? Bad alternator? How are your dash lights?
Old Jun 21, 2005 | 12:47 PM
cleantegra's Avatar
exorcist!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaevo &raquo;</TD></TR><TR><TD CLASS="quote">Maybe a bad ground?</TD></TR></TABLE>
Old Jun 21, 2005 | 12:57 PM
JDM-EJ1's Avatar
Default Re: Light Flickering (cleantegra)
The only thing I can come up with is a bad ground.. If it only one of the lights was flickering I'd say check the bulb itself, but since it's both.. That leads me to believe it's a ground.
Old Jun 21, 2005 | 10:29 PM
FULL-REV's Avatar
Default Re: Light Flickering (JDM-EJ1)
Well i have a thick ground wire running from my engine to the chassis. The only thing i could remember is my cd changer has a ground wire that might of came loose...
could that be the prob?
my dash lights are fine.
Old Jun 22, 2005 | 04:10 AM
JDM-EJ1's Avatar
I don't see how your CD player would affect your headlights. Try checking the connection, it may have came loose, or the condition of the connection just worsened over time.
Old Jun 22, 2005 | 05:51 AM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I don't see how your CD player would affect your headlights. Try checking the connection, it may have came loose, or the condition of the connection just worsened over time.</TD></TR></TABLE>
That's what I was thinking, if it's flickering it sounds like your connection is loose and its vibrating, causing them to go off and on.
Old Jun 22, 2005 | 05:58 AM
JDM-EJ1's Avatar
Default Re: Light Flickering (Sh!ttyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS &raquo;</TD></TR><TR><TD CLASS="quote">
That's what I was thinking, if it's flickering it sounds like your connection is loose and its vibrating, causing them to go off and on.</TD></TR></TABLE>
Yeah, if it's not a ground then it has to be the connection.
Take this for an example.. A battery with bad connector cables won't give the car adequte power and in many cases, the car will not run because of it. Think of it this way with your HIDs. They do work, but it looks like it's not getting a constant source of power, which leads me to believe that it's an issue with the connection.
Old Jun 22, 2005 | 08:11 AM
FULL-REV's Avatar
and its really weird because all my other lights don't flicker so it has to be the wires in the engine bay huh
ladybender
Jun 21, 2007 10:01 PM
Slipknt777
Aug 4, 2004 10:02 AM
Warble
Audio / Security / Video
Mar 5, 2003 07:01 PM
. B i g T R Q
Jan 17, 2002 07:28 PM
