Some Questions about my new ls/vtec
ok so i own a 94 integra rs, is this odb1 or odb2,
i just purchased a 2000 sir b16 head, is this odb1 or odb2
here are some questions i have.
1) what kind of distributor do i need for this ls/vtec
2) what timing belt to use?
3) will adding p30 pistons with ls rods and arp bolts , add any power? without to much compression.
4) will a b16 ecu be the best choice for this setup?
5) Which vtec selenoid do i choose? odb1 or odb2?
6) are crower valve springs and retainers any good for this setup?
7) Will the stock b16 cams, produce good power for this setup?
thanks to all who answer.
Re: Some Questions about my new ls/vtec (fabe85)
your car is obd 1. 92-95 is obd1, 96+ is obd2
1. one that is obd1
2. one that matches the water pump. (ls pump, ls belt. gsr pump, gsr belt)
3. yes
4. depends. get it tuned.
5. i don't think it matters.
6. probably
7. something more aggressive would be better.
1. one that is obd1
3. yes
6. probably
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabe85 »</TD></TR><TR><TD CLASS="quote">also what headgasket will be best choice for this</TD></TR></TABLE>
^ Any 90-01 Integra headgasket will work. You need a VTEC B-series distributor.
OBD-I ECU Options:
P61 USDM 1992-1993 Integra GSR
P28 USDM 1992-1995 Civic EX and Si (must reprogram for DOHC).
P30 USDM 1994-1995 Del Sol DOHC VTEC
P72 USDM 1994-1995 Integra GSR
OBD-I ECU Options:
B16A3Civic*Eg
10
05-24-2006 02:04 PM
