Leak down test
Old Jun 22, 2005 | 02:59 PM
b18c1acura's Avatar
Default Leak down test
What all is involved in a leakdown test? Is this something I could perform on my own like a compression test? If anyone could answer this I would appreciate it.
Old Jun 22, 2005 | 04:26 PM
Ricky Rojales's Avatar
Default Re: Leak down test (b18c1acura)
You'll need a leakdown tester1 or leakdown tester2 and a source of compressed air.
Did you try searching? It's a good habit I think you should develop.
https://honda-tech.com/zerothread?id=386663
https://honda-tech.com/zerothread?id=233858
https://honda-tech.com/zerothread?id=278174
Old Jun 22, 2005 | 04:40 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: Leak down test (=p)
its one of the easiest diagnostic things you can do. BUT, its a waste of time if you do it before a comp. test. if your compression test comes back normal; there is absolutely no reason to take a leak down test. you perform a leak down test to find out the problem if your compression results arent good. and hes right; all you need is the gauge/hose kit, and it connects to air compressors. save yourself the time and do a comp. test first, if your engine isnt running quite right.
civic addict
Sep 12, 2010 07:10 AM
vteg98
Oct 15, 2006 06:07 PM
boostedel
Oct 27, 2002 08:47 AM
Propulsion
Jun 5, 2002 11:48 PM
