TEIN SS
Old Jun 19, 2005 | 10:49 PM
super_mut's Avatar
Default TEIN SS
Well I just recently put on TEIN SS on my car 3 weeks ago. My friend says that the springs settle on it. I bought it w/o the pillowball mounts. I don't see how they could settle...why do I say this? I say this because they are coilovers, on coils. It doesn't make any sense to me. I get some rubbing on my wheel wells left and right also. My tires are Yokohama AVS ES100's 195/50/15. My dampening setting is 8, which was the factory neutral setting which they came with. If I start running full stiff won't I mess them up and have to get them revalved? What do you guys think?
Old Jun 19, 2005 | 10:54 PM
super_mut's Avatar
Default Re: TEIN SS (super_mut)
Is there a break in period on the TEIN SS...I run it pretty hard on canyon runs on neutral 8. I wonder if I'm messing it up...normal driving its no problem.
Old Jun 20, 2005 | 01:36 AM
JFG Kevin's Avatar
well..i had the SS for a while, i keep it pretty low for the ground and i'm only 3 clicks away from being the stiffest...everythin seem to be fine. i been running this settin for 3/4 of the year, no problem. For the break in period, i'm not sure but i'm sure that tein builts their coilover system to handle what is giving to them. Just dont over twist the stem.
Old Jun 20, 2005 | 05:58 AM
nickG's Avatar
full stiff you should be fine..its only when you start running them too soft,over 16 clicks, that you will mess them up..
Old Jun 20, 2005 | 06:05 AM
HONDA_TYPE_R's Avatar
Default Re: TEIN SS (aznstyler119)
There is always settling involved, even with pre-settled springs. Think about it, your taking a spring that has had little to no weight applied to it, and then applying whatever the weight of your vehicle is on top of them. It will compress them, because after all metal is malleable.
I am running TEIN HA's off of the ITR and I am running almost full stiff on them. I got my HA's used, and I run them fairly low and really stiff on the street. I know that continued abuse will eventually wear out the shocks and they will need revalving/rebuilding, so with that said, I would be gentle on them (somewhat), that way you know the will work properly down the road.
CivicInspired
Honda Civic (2001 - 2005)
22
Jul 18, 2007 08:01 AM
NerveAgent
Suspension & Brakes
104
Oct 3, 2005 07:28 AM
GettaluvR
Oct 12, 2003 03:59 PM
spoondc5
14
Aug 4, 2003 08:32 PM
