need help
Old Jun 21, 2005 | 06:51 PM
smitty69996's Avatar
Default need help
i have 96 integra ls with around 120,000 miles. When im driving around i hear this wierd rattling type noise from the engine bay around certain speed most of the time. Its mostly around 30 mph and when on the highway at 70 mph
but it also happens other times. I have no clue what is wrong any help would be appreciated
Old Jun 21, 2005 | 07:22 PM
Kendall's Avatar
Most likely it's something trivial like a loose heatshield.
Old Jun 21, 2005 | 07:52 PM
Backk InTheDA's Avatar
I hate everything
Default Re: (Kendall)
Check your axle's, seriously. When my CV boot went, i didnt know it til i could feel the car riding on the axle, it rattled my dash at high speeds.
There are 2 easy ways to check the boot, the first, and probably the most common sence is to check the boot it self for cracks/tears.
The second is to throw your car in reverse and crank the wheel hard to one side, and go about 15 mph.
Then try turning the opposite way, while still going in reverse, if you hear clicking and popping, your probably on that ball joint and will need to replace that axle, either way.
Good luck
Old Jun 21, 2005 | 07:58 PM
Default Re: (iTR2The3rdGen)
i really hope its not anything that is going to cost a lot to fix due to being in highschool and not having much money.
Old Jun 21, 2005 | 08:33 PM
I hate everything
Default Re: (smitty69996)
Well, do what i told you, and if it is making clicking noises, try to drive it has little as possible, i'll try and find this thread that might interest you, and it will give you some motivation.
Old Jun 21, 2005 | 08:37 PM
I hate everything
Default Re: need help (smitty69996)
Here's the thread, links are busted, but maybe reading it will tell you how big of an issue this can be, too bad the links dont work or you would hide your key from yourself.
https://honda-tech.com/zero...age=1
Old Jun 22, 2005 | 12:09 AM
Moogen Powah's Avatar
Default Re: need help (iTR2The3rdGen)
Is it a metal on metal rattling noise? If so, check underneath your car and look at your heatshields.
Old Jun 22, 2005 | 01:56 AM
GSRerrr's Avatar
Default Re: need help (Moogen Powah)
shouldnt beat heat shields, i have same problems except it is my heat shield, but noises can only be heard goin about 5-10 mph, so i think it has something to do with the engine good luck
Old Jun 22, 2005 | 07:57 AM
Default Re: need help (GSRerrr)
thanks for all of the info. im bringing it to my mechanic tommorrow. I was outside looking under the hood just to see if anything was loose and is the radiator supposed to be not totally tightened? Because mine has a decent amount of wiggle due to not being totally tight. Im gonna go outside now and check the axle like u said to right now.
808zrk
Jun 28, 2012 12:31 AM
TunerShark
25
Nov 4, 2006 03:30 PM
WhiteOnRice
14
Sep 26, 2006 10:16 AM
GReddy SI
12
Jul 17, 2003 04:07 AM
B18C-RnVA
Feb 25, 2002 08:30 PM
