question plz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperX »</TD></TR><TR><TD CLASS="quote">if u reuse your LS header, u can get the exhaust for the LS. </TD></TR></TABLE>
correcto
correcto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">You would buy it for a GSR.</TD></TR></TABLE>
that all depends on whether he retains the ls header and cat or not. i'm trying not to get him confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94IntegraLs04 »</TD></TR><TR><TD CLASS="quote">guys iam swap out my ls motor an puttin in a 94-96 jdm gsr motor on my 94 ls body.</TD></TR></TABLE>
IT DOES NOT MATTER. the shells are physically identical, and both exhaust manifolds will bolt up to the motor. the only thing you should worry about is this:
if you use a gsr ex. manifold and cat, use a gsr exhaust. if you use an ls mani and cat, use an ls exhaust.
I think he ment if he put a GSR motor into his LS and add an HKS exaust..would you feel the difference..
YES AND YOU WILL FEEL THE power of VTAKKKKK!
and ALSO the exaust will bolt right up like everyone said Sheeshnessss SAME CHASSIS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sammysacura »</TD></TR><TR><TD CLASS="quote">Your question doesn`t make any sense. An hks what?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94IntegraLs04 »</TD></TR><TR><TD CLASS="quote">if i swap a gsr engine into my 94 ls body an then i buy a hks hi power wut it be diff or wut would i have to do.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94IntegraLs04 »</TD></TR><TR><TD CLASS="quote">like u know if i go to hksusa.com an buy the hi power for my ls will tht bolt on to the gsr headers</TD></TR></TABLE>
no. the gsr exhaust manifold and cat are different lengths than the ls counterparts. it will not bolt right up without modification.
like it's already been said...
gsr header and cat - buy a gsr exhaust.
ls header and cat - buy an ls exhaust.
this is not rocket science.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">no. the gsr exhaust manifold and cat are different lengths than the ls counterparts. it will not bolt right up without modification.
this is not rocket science.</TD></TR></TABLE>
Yup Common sence
case closed
Yup Common sence
case closed
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
the ONLY time a GSR exhaust would match up to an LS/ITR header is for '00-01 motors.
anything else (in this guy's case too), you HAVE to get a GSR exhaust unless you are gonna get a different cat to fit, or use the LS headers (why??)
