Spring Shop?
Old Jun 20, 2005 | 06:43 PM
DrewQ1's Avatar
Default Spring Shop?
I'm lookin for a good cheap place to get lowering springs installed on my teg in the DC Metro area. Can you guys let me know where there at ASAP. I'm tryin to get them in by friday. Thanks.
Old Jun 20, 2005 | 08:16 PM
Ebony and Ivory's Avatar
Default Re: Spring Shop? (DrewQ1)
if you drive up here to pa, right around the hagerstown area, my buddy will do it form like 70 bucks, or i can do it, its easy
Old Jun 20, 2005 | 08:26 PM
Backk InTheDA's Avatar
I hate everything
Not to at all to remotely answer your question, but if you've ever changed a shock on the car, thats how you do it, you just need a spring compressor.
Old Jun 21, 2005 | 05:51 AM
DrewQ1's Avatar
Default Re: Spring Shop? (iTR2The3rdGen)
I never did it before, and i really dont have any tools around me.
Old Jun 21, 2005 | 06:28 AM
Racermech's Avatar
Tools are a basic ratchet set, box/open end wrenches. (10&12mm most common)
Spring Compressor. A lot of auto parts stores rent these cheap.
It is a real easy thing to do. You remove the shocks, compress the spring, remove the top hat, de-compress the spring and take it off. But the new spring on. You should not have to compress the new spring. Put the top hat on, put the shock back in and you are done. Repeat 3 more times.
Old Jun 21, 2005 | 06:40 AM
shyboy817's Avatar
70 bucks? i still think that's expensive buy me lunch and 20 bucks and i'll do it for you. But yeah as the guy say it's really easy. They're 2 bolts on bottom you need to get off (lower control arm bolt and the bolt on the actually shock). And 2 bolts on top (2 on each side in the engine bay, vice versa in the rear hatch). There's a DIY Article on Team-Integra.net if you look in there.
BB6-213
Honda Motorcycles
Nov 28, 2008 12:28 PM
fireant
26
Oct 2, 2004 02:27 PM
sleeping_forest
10
Nov 11, 2002 08:07 PM
tjtruong
Nov 27, 2001 09:30 PM
