ls vtec question
Now, I know there have been many threads upon this situation, and please consider me new to the honda/acura world... but I have a 95 integra ls b18b1 engine in my 97' civic ex. I would like to convert it over to vtec, and I learned that any b series head will fit. I want to do a full conversion to be safe and do it properly so my engine doesn't go sky-high. What parts are needed in order to do a full converson to make this work properly and efficiently?
Also, which b series head would you prefer?
thx guys
Modified by civicLS97 at 2:09 PM 6/21/2005
thx guys
Did you search first? Here it goes anyways kiddo.
LS/VTEC Swap Part List.
1. DOHC B-series cylinder head COMPLETE with valve cover, intake manifold, VTEC solenoid assembly and internals.
2. VTEC ECU.
3. VTEC B-series distributor.
4. 1990-2001 Integra LS head gasket.
5. 1994-2001 Integra GSR head bolts. This also includes ITR, Del Sol VTEC, and Civic Si.
6. 1994-2001 Integra GSR water pump. This also includes ITR, Del Sol VTEC, and Civic Si.
7. 1994-2001 Integra GSR timing belt or ITR timing belt.
8. 1994-2001 Integra GSR knock sensor. This also includes ITR, Del Sol VTEC, and Civic Si.
9. -4 steel braided hose with female ends (22 inches in length).
10. 1/8 inch NPT female to 1/8 inch NPT female to 1/8 inch BSPT male on run pipe tee.
11. 1/8 inch NPT male to -4 male straight adapter.
12. 3/8 inch NPT male to -4 male straight adapter.
13. 1/8 inch internal pipe plug.
14. 1/8 inch NPT pipe tap.
15. 3/8 inch NPT pipe tap.
16. 14mm drill bit.
17. 10.9mm drill bit.
18. 12mm X 1.25 mm tap.
LS/VTEC head options.
JDM B16A 1989-1991 Civic SiR/SiRII/CRX SiR
JDM B16A 1990-1993 Integra Rsi/Xsi
JDM B16A 1992-1995 Civic SiR/SiRII
JDM B16A 1992-1995 Ferio Si/SiII/SiR/RTSi 4WD
JDM B16A 1992-1997 CRX Del Sol SiR/SiRII
JDM B16A 1996-2000 Civic SiR/SiRII
JDM B16B 1998-2000 Civic Type R
JDM B18C 1994-1995 Integra Si-VTEC
JDM B18C 1996-1997 Integra SiR-G
JDM B18C 1996-2000 Integra Type R
USDM B16A3 1994-1997 Del Sol DOHC VTEC
USDM B16A2 1999-2000 Civic Si
USDM B17A1 1992-1993 Integra GSR
USDM B18C1 1994-2001 Integra GSR
USDM B18C5 1997-2001 Integra Type R (Exclude 1999)
2. VTEC ECU.
16. 14mm drill bit.
JDMbull
Nov 8, 2006 12:49 PM
b20civicboi
Jun 17, 2005 01:26 PM
