9006 conversion?
Old Jun 22, 2005 | 12:14 PM
TrueUntilDeath.com's Avatar
Default 9006 conversion?
im not talking about the 9005 conversion. im wondering if its possible to put a 9006 bulb into the 9005 socket. thanks
Old Jun 22, 2005 | 12:16 PM
s2kdre's Avatar
Default Re: 9006 conversion? (FrostWhiteDC4[Loveless])
it almost fits, im sure you could cut some of the plastic.
Old Jun 22, 2005 | 12:19 PM
Default Re: 9006 conversion? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">it almost fits, im sure you could cut some of the plastic.</TD></TR></TABLE>
yea, im going to try that method also. i just wanna hear from people who have actually done it a different way. thanks!
Old Jun 22, 2005 | 12:30 PM
HGZ's Avatar
HGZ
im guessing youre trying to make the 'high beams' your regular headlights (with the 9005's in the projectors?? hmm.....)..
.. because i would think you would lose brightness if you replaced the 9005 with a 9006 if you are keeping the high beams where they're at..
Old Jun 22, 2005 | 12:34 PM
Default Re: 9006 conversion? (HGZ.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HGZ. &raquo;</TD></TR><TR><TD CLASS="quote">im guessing youre trying to make the 'high beams' your regular headlights (with the 9005's in the projectors?? hmm.....)..
ur kinda right. i have DRLS (high beams are on when ignition is turned on) but the bad part about it is that the high beams are at about 80% power output, i want to try and put in a 9006 and see if it will be dimmer
Old Jun 22, 2005 | 01:10 PM
HGZ's Avatar
HGZ
i see now.. i forgot about DRLs!
im not too positive, but i think its just a matter of trimming off parts of the 'tabs' on the base of the 9006 bulbs.
good luck!
Old Jun 22, 2005 | 01:14 PM
njandrewg's Avatar
can't you just pull the fuse in the DRLs? Or just take out the bulb itself out?
Old Jun 22, 2005 | 01:23 PM
Default Re: 9006 conversion? (njandrewg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">can't you just pull the fuse in the DRLs? Or just take out the bulb itself out?</TD></TR></TABLE>
i dont want it to be off, i just want it to be dimmer
Old Jun 22, 2005 | 02:19 PM
njandrewg's Avatar
9006's won't be that much dimmer, just go to radio shack and buy the electrical stuff that will make it dimmer. Not sure what they are called, resistors? or something like that
Old Jun 22, 2005 | 02:22 PM
Dc2 Powered's Avatar
get a rely and a dimmer switch.. lol kenny has one of those for his headlights i have no idea why but yea it works.
Old Jun 22, 2005 | 02:39 PM
Default Re: (Dc2 Powered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2 Powered &raquo;</TD></TR><TR><TD CLASS="quote">get a rely and a dimmer switch.. lol kenny has one of those for his headlights i have no idea why but yea it works.</TD></TR></TABLE>
already have a relay.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">9006's won't be that much dimmer, just go to radio shack and buy the electrical stuff that will make it dimmer. Not sure what they are called, resistors? or something like that</TD></TR></TABLE>
the thing with resistors is that you cannot put a cover over it becuase it gets too hot. i dont wait to have a piece of metal being free to touch.
Old Jun 22, 2005 | 02:55 PM
AngelTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostWhiteDC4[Loveless &raquo;</TD></TR><TR><TD CLASS="quote">]
ur kinda right. i have DRLS (high beams are on when ignition is turned on) but the bad part about it is that the high beams are at about 80% power output, i want to try and put in a 9006 and see if it will be dimmer </TD></TR></TABLE>
DRLS have the high beams on while running?
-Mike
Old Jun 22, 2005 | 09:01 PM
Default Re: 9006 conversion? (AngelTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AngelTeg &raquo;</TD></TR><TR><TD CLASS="quote">
-Mike</TD></TR></TABLE>
mine was DIY
pnoipj89
Jan 17, 2007 01:33 PM
Topgun98
Aug 7, 2005 06:23 PM
DC2 to AP2
Honda Motorcycles
17
Oct 16, 2004 02:07 PM
weakGOODJunKieS.com
Jan 26, 2004 08:41 PM
