Overheating problems, help!!
Old Jun 20, 2005 | 08:31 PM
Ebony and Ivory's Avatar
Default Overheating problems, help!!
I am having issues with overheating, I changed the thermostat, and then refilled the entire radiator, and fill the overflow to the max line. I'm still running hot, whats going on. it gets hot when I'm sitting, but then when i drive, it goes down to about half, please help, I dont want this motor to blow
Old Jun 20, 2005 | 08:49 PM
denraweb's Avatar
Default Re: Overheating problems, help!! (The Peezy Fo Sheezy Neezy)
Are your radiator fans working? Let the car idle and watch it for like 5 min after reaching normal operating temperature. Then watch the fans and see if they activate. I had the same problem, and mine was a bad fan power connection. I got a new connector and my car stayed at normal temp.
fabe85's Avatar
hmm, this sounds like the problem i have. I was told i need to change my water pump. this might work for you.
Old Jun 21, 2005 | 12:57 PM
cleantegra's Avatar
waterpump or blown head gasket more than likely
Old Jun 22, 2005 | 09:31 PM
EnjoyTheRideDC2's Avatar
Default Re: Overheating problems, help!! (cleantegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Peezy Fo Sheezy Neezy &raquo;</TD></TR><TR><TD CLASS="quote">I am having issues with overheating, I changed the thermostat, and then refilled the entire radiator, and fill the overflow to the max line. I'm still running hot, whats going on. it gets hot when I'm sitting, but then when i drive, it goes down to about half, please help, I dont want this motor to blow </TD></TR></TABLE>
usually signs of: Bad thermostat
Worn Head Gasket
Bad Water pump
Or even air getting into the system
Old Jun 22, 2005 | 09:43 PM
MOVE OVER's Avatar
Default Re: Overheating problems, help!! (EnjoyTheRideDC2)
speaking of air in the system. when u drained and filled it back up. did u leave the rad cap off and let it warm up and boil over? u can try that to get the air out. hope its not a water pump. thats the kinda thing u only wanna have to do when u plan on it, with the timing belt at a given mileage
hope u get it fixed
Old Jun 22, 2005 | 10:09 PM
GWInquisitor14's Avatar
Default Re: Overheating problems, help!! (ITR 1102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 1102 &raquo;</TD></TR><TR><TD CLASS="quote">speaking of air in the system. when u drained and filled it back up. did u leave the rad cap off and let it warm up and boil over? u can try that to get the air out. </TD></TR></TABLE>
or u can just bleed it w/ the bleeder screw. Id say check your fans first, its the easiest thing to do and to replace over a water pump and head gasket.
Old Jun 22, 2005 | 10:18 PM
MOVE OVER's Avatar
Default Re: Overheating problems, help!! (GWInquisitor14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">
or u can just bleed it w/ the bleeder screw. Id say check your fans first, its the easiest thing to do and to replace over a water pump and head gasket. </TD></TR></TABLE>
yea, but the cap is on top, less work. also that will work on all cars - without having bleeder screw
Old Jun 22, 2005 | 10:21 PM
1bar's Avatar
did you try squeezing the return hose into the rad? Sometimes you can squeeze them and it will remove the air pockets in the system itself.
Old Jun 23, 2005 | 06:52 AM
typet's Avatar
use the bleeder screw after reaching operating temperture, leave the cap off until the fans turn on and make sure that the coolant level is full. Also if you see bubbles flowing in the radiator (cap off) then you know you have a blown head gasket. Also the oil may have a white milky substance which is the coolant mixing with the oil.
Old Jun 23, 2005 | 02:06 PM
figured it out guys thanks, there was air in the radiator, and the fans weren't coming on?
eg6madness
Aug 17, 2006 08:39 PM
integraloco
Nov 14, 2005 08:55 AM
tonezilla
Mar 22, 2004 07:35 PM
nek0
Jun 16, 2003 05:05 AM
Gabe_
12
Jun 13, 2003 02:47 AM
