BOV??
Old Jun 20, 2005 | 05:46 PM
weak_tec's Avatar
Default BOV??
im buying piece by piece parts for my turbo setup, was just wandering can a bov screw up your idle timing. i heard some stories about this, but wasnt sure...
also if i do buy it, which one should i go with?
Old Jun 20, 2005 | 06:54 PM
RidinStock's Avatar
Default Re: BOV?? (spoon_meeH)
No, a BOV is a critical component of a turbo setup. Here's the best illustration I can give of what a BOV does (hopefully I remember it right).
Imagine sucking on a straw, and all of a sudden plugging the end. The sudden shock messes up the straw and kinda hurts your mouth if it were to happen a lot. Now imagine that when you plug the end, the side opens up to release that pressure, giving you a chance to stop w/out damaging the straw or your mouth. It's the same concept with the throttle plate (i think!).
Please correct me if I'm wrong!
Old Jun 20, 2005 | 07:06 PM
Backk InTheDA's Avatar
I hate everything
Default Re: BOV?? (RidinStock)
Yeah, that pretty much somes it up, just an area to release pressue. It's a must, there's a reason why a BOV comes with a setup, and its not just for the noise.
Old Jun 20, 2005 | 09:02 PM
RidinStock's Avatar
Default Re: BOV?? (iTR2The3rdGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iTR2The3rdGen &raquo;</TD></TR><TR><TD CLASS="quote">and its not just for the noise.</TD></TR></TABLE>
Even though it is one of the sexiest noises out there IMO.
Old Jun 20, 2005 | 09:05 PM
93_teg_CT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinStock &raquo;</TD></TR><TR><TD CLASS="quote">Even though it is one of the sexiest noises out there IMO.
Old Jun 21, 2005 | 03:18 AM
jaydeemmmm's Avatar
Default Re: BOV?? (93_teg_CT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jun 21, 2005 | 05:18 AM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_meeH &raquo;</TD></TR><TR><TD CLASS="quote">im buying piece by piece parts for my turbo setup, was just wandering can a bov screw up your idle timing. i heard some stories about this, but wasnt sure...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_meeH &raquo;</TD></TR><TR><TD CLASS="quote">also if i do buy it, which one should i go with?</TD></TR></TABLE>
Your stories are true....however, NOT with cars like ours. Our intake system uses a MAP sensor instead of many other cars which use a MAF. In some cases, a BOV may affect that system differently.
One that fits your budget and works well. NOT one that sounds "uber cool and loud". I had the HKS Super Sequential. Great BOV.
Old Jun 21, 2005 | 05:54 PM
weak_tec's Avatar
Default Re: BOV?? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
Your stories are true....however, NOT with cars like ours. Our intake system uses a MAP sensor instead of many other cars which use a MAF. In some cases, a BOV may affect that system differently. </TD></TR></TABLE>
i knew someone would know..
Old Jun 21, 2005 | 07:11 PM
Newman's Avatar
New User
To answer the question since I didn't see anybody fully answer it...... the bov can screw with your idle if it's leaking. That's because the screw is usually too loose because people like to loosen up the screw a lot to allow the bov to 'make the sound last longer' while releasing boost into the atmosphere. The best way to adjust it is to start the car and let it idle, and adjust the bov screw until you cannot feel any air coming out of it.
Old Jun 21, 2005 | 08:23 PM
zeroz's Avatar
Hand_Fed
Apr 22, 2010 04:51 PM
1 Cam Wonder
Dec 14, 2004 03:52 PM
Snafu-Si
Jun 3, 2004 10:32 AM
hi mom
Jan 29, 2004 06:46 AM
DigitalFusion
Jun 11, 2002 05:54 PM
