Engine Mounted wrong!!!!
Old Jan 3, 2006 | 05:26 PM
JBirch_97Prelude's Avatar
Default Engine Mounted wrong!!!!
I am getting alot of vibration and noise from my engine, more on the driver side. Some of the noise sounds like it is coming from the cam gears (stock). I was told by a Acura service center that the motor mounts was broken front L/R and it should stop the Vibration and some of the noise. I replaced the Motor mounts right side mounted with ease but the left side (driver side) was not aligned and we were not able to put Mount back on. So me and the mechanic put a jack under the oil pan with a wooden block to put it into alignment. Once the motor mount was on we lowered the jack and the Engine just kept going down with it. So the engine looks okay from the top but it is actually leaning down on the left (driver) side. The mechanic said it may need frame work? What do you think?
Old Jan 3, 2006 | 05:45 PM
b20integrapower's Avatar
Default Re: Engine Mounted wrong!!!! (RippleSound)
whoa...so it started leaning AFTER he worked on it? well he better be the one responsible for fixin it
Default Re: Engine Mounted wrong!!!! (b20integrapower)
and frame work? that bs if he is the one that messed things up
Old Jan 3, 2006 | 05:50 PM
No he didnt, I should have mentioned it was previously totaled in the front. R-title.
Old Jan 3, 2006 | 05:52 PM
Also the engine is a 1994-1995 LS engine inside a 1996 GSR.
Old Jan 6, 2006 | 10:39 PM
Dutch-VTEC's Avatar
1st, I dont know why you would put an ls in a gsr. 2nd it could be your frame. Was your car ever in an accident. You could also have the wrong motor mount bracket which could make it not line up.
Old Jan 7, 2006 | 01:35 AM
The Phil's Avatar
Default Re: Engine Mounted wrong!!!! (1HONDAEXPERT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1HONDAEXPERT &raquo;</TD></TR><TR><TD CLASS="quote">1st, I dont know why you would put an ls in a gsr. 2nd it could be your frame. Was your car ever in an accident. You could also have the wrong motor mount bracket which could make it not line up.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RippleSound &raquo;</TD></TR><TR><TD CLASS="quote">No he didnt, I should have mentioned it was previously totaled in the front. R-title.
Duh.
Are you using the right mounts? Can you take a picture of the new and old mounts together?
enerlevel
Jan 20, 2008 09:24 PM
integdriver4
Sep 9, 2007 10:51 PM
Accord_Kid
Jun 18, 2004 04:19 PM
Cyber ITR
Jan 2, 2004 02:02 AM
rexorz
Feb 18, 2003 01:35 PM
