Wired tach problem when vtec kicks.
Old Jan 3, 2006 | 06:12 PM
Nataku's Avatar
Default Wired tach problem when vtec kicks.
It seems that when vtec engages my tach starts jumping around. I've been told it could be something to do with the distro...
any ideas?
Old Jan 3, 2006 | 06:57 PM
LoseRPunKx182's Avatar
Default Re: Wired tach problem when vtec kicks. (Nataku)
jumping rpms could be cause by bad connection inside the distributor...if it's only during vtec then i dunno if it's the same problem
Old Jan 4, 2006 | 08:23 AM
Nataku's Avatar
Default Re: Wired tach problem when vtec kicks. (LoseRPunKx182)
I've seen it happened before without vtec. but it mostly happens at that point.
if you are right what is involved in fixxing it?
Old Jan 4, 2006 | 08:30 AM
smallsvw's Avatar
Just take off your dist. Cap and check the connectons on the inside.
When vtec hits Im sure is causes alot more vibration per say then driving -4k.
Old Jan 4, 2006 | 08:31 AM
Default Re: (smallsvw)
http://www.g2ic.com/tegtips/engine/10.html
miket1211
Mar 22, 2010 05:17 AM
sileighty_911
Sep 13, 2007 09:53 PM
efHatchbackJake
13
Apr 8, 2005 12:05 PM
hybridbmw
Jul 25, 2002 09:55 PM
JDM 007
May 27, 2002 02:02 PM
