help
Old Dec 31, 2005 | 12:33 AM
buggier1013's Avatar
Default help
i have a 91 integra with a b18b1. I am running a obd0 in it and it idles funning and the rev limiter is at 3 grand i was just wondering if that had anything to do with having the wrong ecu in it for that motor and help would be appriciated thanks
Old Dec 31, 2005 | 08:04 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help (buggier1013)
Check for stored codes. It sounds like your ECU is in "limp" mode.
Old Dec 31, 2005 | 08:49 AM
ernald711's Avatar
Default Re: help (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Check for stored codes. It sounds like your ECU is in "limp" mode.</TD></TR></TABLE>
oooo... that sucks.
Old Dec 31, 2005 | 04:47 PM
i checked the codes and it says that the crankshaft sensor is out or not working right to chang that i have to change the distributor and know of a distributor for sell cheep or another way of fixing it
Old Jan 1, 2006 | 06:52 AM
cbondura's Avatar
sounds like you need to get the right ecu for the engine. swapping ecu's is fairly easy and they are easy to find/sell on ebay.
Old Jan 1, 2006 | 02:06 PM
d16vtecx's Avatar
Default Re: help (cbondura)
what ecu are you running
Old Jan 1, 2006 | 05:48 PM
Default Re: help (d16vtecx)
obd0 pr4 would the ecu make a diffrence if they didnt change the wiring harnes when they did the motor swap or are just using a b18b1 block
stewforyou
Feb 23, 2005 09:01 PM
dwchkypmp20
13
Jan 17, 2004 04:51 PM
halfNhalf-83
Nov 27, 2003 09:29 AM
TurboRedSi
Jul 17, 2003 10:59 PM
crxtreme27
Jul 1, 2003 04:30 PM
