o2 sensor help
Old Jan 2, 2006 | 10:29 AM
gATOr65's Avatar
Default o2 sensor help
i just recently took off my cat on the gsr and now i want to put it back on. my prob. is that the 4 wires on the 1st o2 sensor i dont know how they hook up. any help woul be appreciated.
Old Jan 2, 2006 | 01:39 PM
TypRice's Avatar
it should just plug up...unless u hacked them...
green to green...white to white...both blacks to both blacks
Old Jan 14, 2006 | 03:05 PM
gATOr65's Avatar
Default Re: (TypRice)
can someone please help me! my wires are diff.. its a 97 gsr , and ive already looked at this thread. does someone have a pic of a o2 sensor hooked up?
Quote, originally posted by Skelly »
spend 2 minutes and do a search https://honda-tech.com/zerothread?id=1091495
Old Jan 14, 2006 | 03:20 PM
Padawan's Avatar
Darth ModerVader
Default Re: (gATOr65)
I'm honestly not sure what you're asking. There isn't any wiring work involved with the O2 sensor - it just plugs in to the harness.
Old Jan 14, 2006 | 03:46 PM
gATOr65's Avatar
Default Re: (Padawan)
the 4 wires, 2 black, 1 green , and 1 white. the four pins came out of the # 1 02 sensor. so i was looking at the diagram on the link that i have, and it makes no sense.
Old Jan 15, 2006 | 12:56 AM
import810's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gATOr65 &raquo;</TD></TR><TR><TD CLASS="quote">the 4 wires, 2 black, 1 green , and 1 white. the four pins came out of the # 1 02 sensor. so i was looking at the diagram on the link that i have, and it makes no sense.</TD></TR></TABLE>
I will help clarify since I did the same thing. 4 wire run into a plastic piece which connect to another plastic piece with 4 wire in it. The wires were pulled out from the plastic piece and he needs to know witch way to put them in. I eventually guessed and got it.
Old Jan 15, 2006 | 01:06 AM
tur3oDC4's Avatar
Default Re: (import810)
Same thing happened to me. I had to look at another integra to figure it out.
Old Jan 16, 2006 | 11:03 AM
gATOr65's Avatar
Default Re: (tur3oDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tur3oDC4 &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to me. I had to look at another integra to figure it out.</TD></TR></TABLE>
that is why i am asking if anyone has pics of theirs plugged in, or if they can help me out
Old Jan 16, 2006 | 03:39 PM
import810's Avatar
Default Re: o2 sensor help (gATOr65)
hey man I found this it worked for me so good luck
http://www.hybridautomotive.com/tech/o2/#seven
Kegan
16
Nov 14, 2013 07:26 PM
novtecnoboost
Feb 11, 2007 06:56 PM
01blackgsr
Jun 24, 2006 06:23 PM
integra686
Jul 2, 2005 02:33 PM
