another question
Old Jan 1, 2006 | 08:32 AM
petergriffen's Avatar
Default another question
ok so i have been leaving post about my proble with me 95 ls. it all started when i blow a 10a fuse for my dahs lights and tail lights. so now when ever i put an new 10a fuse in not a bigger amp becuase that will cause fires. but when ever i put a new fuse in as soon as it turn my dash lights on it blows. so i have narrowed it down to either a short i a wire somewhere or theres a postive wire touching a ground. ok.... so recently i took my spoiler off( i think tegs look better without them ) and i had all the holes pluged expect one and while that one hole wasnt pluged it rained now it rained on it all night (christmas eve) . and i just got new taillights and there was an imense amount of water in the left side tailight where the hole wasnt plugged. ok now heres my questoin (finally) . could this have shorted out a wire causing my dahs lights tonot work and blow a fuse each time i reaplce it ? hmmmm please help and if you do think so how to i check for shorts. i have a volt meter just dont know how to use it the sitiation. thanks
Old Jan 1, 2006 | 11:09 AM
Default Re: another question (petergriffen)
ok i think i have narrowed it down some more. i think the problem might be coming from the switch for the dash lights. not the dimmer but the switch on the left side of the steering wheel. question, how do i get to this switch so i can inspect it i tried taking the cover around the steering colum off but still nothing.
FranchiseAccord
Nov 21, 2008 02:52 AM
blackakkord
Jan 31, 2008 05:46 PM
574-90da
Sep 7, 2007 03:30 PM
4DooRGiSzer
Mar 31, 2005 06:44 PM
pompous
Dec 23, 2004 08:57 AM
