hydro locking
Old Feb 14, 2007 | 07:42 AM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
Default hydro locking
can someone explain to me exactly wat this does to you? wat do you replace to get the motor running right again?
Old Feb 14, 2007 | 07:48 AM
ac_attak's Avatar
Default Re: hydro locking (99hondacura)
http://en.wikipedia.org/wiki/Hydrolock
Old Feb 14, 2007 | 07:51 AM
ac_attak's Avatar
You can try and get your insurance company to cover repairs. If it happened due to flooding and you were using stock intake insurance may cover it. If you weren't using the stock intake then just put it back on and say you were.
Old Feb 14, 2007 | 07:56 AM
yea we were using a cai
Old Feb 14, 2007 | 07:59 AM
really good info thanks!
Old Feb 15, 2007 | 12:56 AM
Sam92Teg's Avatar
Default Re: (99hondacura)
I hydro locked my engine while running a CAI across a very shallow skim of water. I would say around 4 or 5 inches deep, yet the CAI managed to draw the water up into the cavity where the filter resides.
The article was right about usually bending a rod. If you don't attempt to restart the engine, the hydro lock might not cause any damage. But trying to restart and forcing the starter to bend the rod as it turns the crank, this is usually where the damage occurs.
I disagree with the statement in the article about it not being economically feasible to repair an engine with a bent rod. When I had my car towed after hy locking it, I pulled the pan immediately to look at the rods. I new the clack, clack, clack, noise it was making had to be a bent rod. Sure enough, when I got there, the rod was bent, I could see using a flashlight looking past the crank. I ordered a new rod from Acura and pulled the head, rod and piston assembly and had the local machine shop swap the rod. Total cost for my weekend repair, around $150 for rod and bearing. Sounds economically feasible to me.
I have put on 52K miles since the rod swap, and it revs out just fine, all is well. I got lucky and reused my old piston and rings, head gasket, head bolts, and oil pan gasket, with no problems at all.
Old Feb 15, 2007 | 01:31 AM
turbociviccoupe's Avatar
Default Re: (Sam92Teg)
can also hydro lock from liquid injection lol...saw it on water injection once.
hyogen
Honda Civic (2006 - 2015)
62
Jan 13, 2007 10:05 AM
dank24
Jul 6, 2006 09:45 PM
Tad
Sep 12, 2003 06:29 AM
J337_UNIT
Jul 22, 2003 10:24 PM
BoM
Jul 4, 2001 09:28 AM
