quick compression question (GSR)
Old Feb 14, 2007 | 06:11 PM
ekhatchturbo's Avatar
Default quick compression question (GSR)
just wanted to know the factory GSR b18's compression (psi and ratio) and what would the psi be if I'd chose to go with 9.0.1 J/E pistons? that's it. thanks for the help guys.
Old Feb 15, 2007 | 05:15 AM
Default Re: quick compression question (stevevangst)
anyone?
Old Feb 15, 2007 | 05:16 AM
Preferio's Avatar
There is a website where you can put in all the information, and it will tell you the compression ratio... I'll try and find it.
Old Feb 15, 2007 | 05:19 AM
Preferio's Avatar
Default Re: quick compression question (PreFerio)
c-speedracing.com is where its at. According to AllData:
COMPRESSION AT 250 RPM AND WIDE OPEN THROTTLE:
Nominal 1860 kPa (270 psi)
Minimum 930 kPa (135 psi)
Maximum Variation 200 kPa (28 psi)
Old Feb 15, 2007 | 05:31 AM
thank you so much, that was easy.
michaelcal12
Honda Civic (2001 - 2005)
Dec 13, 2012 07:49 AM
pettyboy69
Jun 22, 2009 07:39 AM
flatblack-h22
Jul 16, 2007 01:23 PM
TeStUdO
May 5, 2003 05:28 PM
turboex
Mar 29, 2002 08:38 AM
