side markers
Old Feb 12, 2007 | 04:26 PM
Daammnn's Avatar
Default side markers
hate to ask but ive searched and i really need the right measurments does anyone have a template for the DC2?? thanks.
Old Feb 12, 2007 | 05:03 PM
Daammnn's Avatar
bump....anyone??
GSRdude's Avatar
Default Re: side markers (Daammnn)
didn't search hard enough......found it the faqs......you can find a lot of info there.....I think you should try the faq 1st then the search button!
http://www.integra.orcon.net.nz/indicator.htm
Old Feb 12, 2007 | 05:06 PM
Daammnn's Avatar
thats for a DA is it not?
Old Feb 12, 2007 | 05:08 PM
GSRdude's Avatar
Default Re: (Daammnn)
I suppose your right...I'll keep looking since I gave you a hard time....I have seen it before.
Old Feb 12, 2007 | 05:12 PM
Daammnn's Avatar
haha its cool man, i even searched on team integra but no one has the template for a DC2
Old Feb 12, 2007 | 05:27 PM
GSRdude's Avatar
here you go....https://honda-tech.com/zerothread?id=1339229
now thats a pdf file, which I didnt check out so, if its not what you need I will keep looking
Old Feb 12, 2007 | 05:41 PM
Daammnn's Avatar
yah that showed how to do it but it didnt have any measurments i dont know why i havent seen any damn templates for a dc2
Old Feb 12, 2007 | 05:43 PM
GSRdude's Avatar
I know I have seen one. It basically lines up with the inside of the fender and the body line.
Old Feb 12, 2007 | 05:45 PM
Daammnn's Avatar
yah that makes since i guess you just gotta make sure it lines up. i dunno.
Old Feb 12, 2007 | 05:59 PM
GSRdude's Avatar
this is the one I was talking about...little suprised I found it......hope this one helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">yep I just replaced my imitation OEM sidemarkers w/ genuine OEM Stanley sidemarkers, the fit is like night and day difference!
Here's the pic I made:
I think in reality that 3/4" measurement is more like 1/2".
I also have a diagram showing the exact measurements of the cutout, but I can't find it on my computer at the moment.
What I did was remove the fenders from my car (actually I did the driver side one on my new black fender before installing it), drew the diagram at actual size in AutoCad and printed it out, then taped it to the BACK of the fender in the correct location. Then I used an Xacto to cut the paper diagram along the lines, which left score lines in the backside of the fender sheetmetal. Then I drilled a hole and used my metal nibbler from Radio Shack to make the hole.
When I made the holes on my old fenders, I was cutting from the back of the fender, having the nibbler poke thru to the front. Unfortunately this made a little paint chip off near the edges of the holes. On these fenders I made the marks for the hole on the backside so that I could stick the nibbler thru from the front and follow it along the lines on the backside so that it wouldn't chip the paint off. I put down masking tape on the front so the nibbler wouldn't scratch the paint, although my fenders need to be painted anyway so it didn't matter that much. HTH, I'll try to find the hole measurements.</TD></TR></TABLE>
Old Feb 12, 2007 | 06:05 PM
Daammnn's Avatar
thank you very much
Old Feb 12, 2007 | 06:14 PM
GSRdude's Avatar
no problem, you might try contacting Patrick and see if he found his autocad template or whatever.
Old Feb 12, 2007 | 07:06 PM
OMG THE GOGGLES's Avatar
Default Re: (GSRdude)
All of the templates youll find on the net at the time when I started doing these SUCKED. My best suggestion to you, is to just measure the inner box of the sidemarker, and cut around 3-5mm within that space after you stencil it on the fender, trial and error for what you need to shave off/widen/extend/shape etc. Its very easy to get them done PERFECT, if you take your time. I do suggest a dremel though, and not an air tool...I feel if you have a decent dremel you can control the speed much better.
Old Feb 12, 2007 | 07:36 PM
Daammnn's Avatar
yah thats a good idea thanks for the help guys.
Old Feb 12, 2007 | 11:36 PM
My_EFsedan's Avatar
actual size template
heres how it looks on my friends car when i did it
Old Mar 8, 2007 | 10:03 PM
LsHoney84's Avatar
Default Re: (My_EFsedan)
after installing the sidemarker, did it move or was it snug?
Dan-dc2
Feb 28, 2011 08:18 AM
dj theoretic
Jan 13, 2009 06:51 PM
Ramon96LS
Feb 27, 2008 12:41 AM
TotalBalance
Feb 9, 2008 01:10 PM
Carnage R1
Jan 19, 2005 07:21 PM
