cluster problem!
Old Feb 11, 2007 | 03:38 PM
roger93si's Avatar
Default cluster problem!
I recently purchased a 92 teg. the owner before had white face guages on it so i took them off cuz thats not my style, but now my gas needle is not workin it stays down.. is there a way to reset it, it was workin fine before! thanx guys!
Old Feb 11, 2007 | 05:48 PM
BlueIntegraBoy's Avatar
Default Re: cluster problem! (roger93si)
You probably damaged it while uninstalling the faces. You can buy a replacement fuel gauge from the dealership.
Old Feb 11, 2007 | 06:16 PM
roger93si's Avatar
Default Re: cluster problem! (BlueIntegraBoy)
are u serious i probably damaged it !!!!!! f***... do u know how much they run?.. or am i better off buying a used or jdm cluster?
Old Feb 11, 2007 | 06:20 PM
Just found out for 90-93 Integras, you can't order each gauge separately from the dealer, only the whole cluster. In that case, you are better off buying a used cluster.
Old Feb 11, 2007 | 06:38 PM
AP1Shocker's Avatar
do you remember hitting it? I know the needles themselves are supposed to be very brittle but I dont know about the rest of the gauge.
When I bought my teg the gas gauge didnt work, the previous owner said it needed a new fuel sending unit, so $80 later and a couple hours of labor it still didnt work .. ended up being some wire went to the wrong pin in the cluster harness. Anyways even though that has nothing really to do with your problem, be careful not to blow your money on a part you dont need
Old Feb 12, 2007 | 01:31 AM
roger93si's Avatar
Default Re: cluster problem! (DC4Shocker)
thanks guys, i might mess with it a little to see if i can get it to work.. if not then im getting a jdm one,...
MTarry
11
Jan 15, 2013 06:46 PM
MattNYC
11
Oct 29, 2010 02:12 PM
NsX_CrX
May 30, 2005 04:55 PM
spoon063
Mar 30, 2004 10:27 PM
