quick???????
Old Feb 13, 2007 | 05:36 AM
frankenstienEk's Avatar
Default quick???????
if timing is slightly off, can it cause a small jumpy idle? because just finished changing a camshaft seal tryed to put it back in timing (did the best i can) and now at idle it has a little stupid jumpy idle when it was perfect before i did the work. thanks
Old Feb 13, 2007 | 06:25 AM
aaronISthrowed's Avatar
Default Re: quick??????? (frankenstienEk)
Your idle will be a little jumpy if the battery is disconnected and then hooked back up again, but thats only for like 10 minutes, that may be your problem.
Old Feb 13, 2007 | 06:40 AM
Default Re: quick??????? (aaronISthrowed)
no, thats not my problem because nothing was touched but the work that i did ,which was taking the valve cover off and losing belt tensioner and taking the cam gear off and replacing the seal.
Old Feb 13, 2007 | 07:07 AM
lVlemphizStylez's Avatar
lumpy idle can be a timing issue...
Old Feb 13, 2007 | 07:15 AM
Default Re: quick??????? (lVlemphizStylez)
thanks!!!!
Old Feb 13, 2007 | 09:55 AM
hondata151's Avatar
PremiumPrelude
Mar 23, 2008 03:45 PM
dc2LS
Jan 18, 2008 06:06 PM
civickiller
Feb 15, 2007 12:38 AM
NoVALude
Nov 20, 2006 11:02 AM
guywitaDA
Jul 27, 2005 01:15 PM
