help with non abs conversion!!!
Old Feb 14, 2007 | 01:09 PM
myfirstdc2's Avatar
Default help with non abs conversion!!!
hi im new to honda-tech. and i don't know how to use this site very well. i have a 95 integra ls and i want to do a non abs conversion. reason for doing so is because im the abs pump and some brakes lines. i already bought the rs lines and the non abs master cylnder . what im wondering is do i need to get the non abs brake booster as well? please help. i really want my car to drive. well actually stop haha thanks in advance if i get any help.
Old Feb 14, 2007 | 01:11 PM
muscleinnovation's Avatar
Default Re: help with non abs conversion!!! (myfirstdc2)
hi im also new as well. and my question is also the same. i need help with my brake too. i have a similar problem like yours. im not to sure if u need the brake booster, but what i can tell u is that u might have to drop the gas tank to get the the rear brake lines out.
Old Feb 15, 2007 | 06:45 PM
myfirstdc2's Avatar
Default Re: help with non abs conversion!!! (muscleinnovation)
bump!!!
Old Feb 16, 2007 | 07:37 PM
myfirstdc2's Avatar
please help!!! bump!!!
Old Feb 16, 2007 | 07:54 PM
JDMorgan's Avatar
you need the master cylinder AND booster, or you can reflare the m10 rs line to an m12 fitting(reuse the abs fitting). then of course you need the rs front lines , rs mc lines and prop valve.
EDIT: do not take the rear lines out. they are the same on all teg's.
Old Feb 16, 2007 | 10:04 PM
Blk-dc2's Avatar
Default Re: (JDMorgan)
couldn't they just use the rs prop valve and bend there own lines???
Old Feb 17, 2007 | 04:50 AM
JDMorgan's Avatar
Default Re: (Blk-dc2)
yea but if you use pre-flared lines you would need to reflare one of the lines going into the master cylinder to m12 in order to use the gsr master cylinder.
Old Feb 17, 2007 | 11:39 AM
myfirstdc2's Avatar
ok thank you so much. for the help. it look like all i have to do now is buy the booster then. i already boought all the front lines and bmc. i appreciate the help guys. i was under the impression that the brake booster didnt matter cuz the bmc bolted rite up with no problems in fitment. and good thing u told me about the rear lines as well. cuz those things are expensive.
Old Feb 19, 2007 | 09:57 PM
o well that sucks. i guess i swapped out the rear lines for nothing hahaha. o well at least i know they are new. awesome info guys. i wish i knew ealiar. o but quick question. i used the 94 ls abs booster witht he 95 rs master cylnder and it bolted up fine.it still brakes ok i think anyway. seems like np. do u think i should still change it?
Old Feb 19, 2007 | 10:18 PM
bg-33p's Avatar
https://honda-tech.com/zerothread?id=1160671
Old Feb 19, 2007 | 11:53 PM
Default Re: help with non abs conversion!!! (bg-33p)
already read that post. but thx for being so cool
sh4mr0ck
Jul 23, 2009 07:21 AM
Sivic90
Nov 14, 2008 04:23 AM
ls19integra95
Dec 2, 2007 03:52 PM
teggy2uner18
Jun 13, 2006 12:42 PM
