Please help.. Idle issue
Old Feb 14, 2007 | 09:17 AM
94Integra_Ls's Avatar
Default Please help.. Idle issue
I'm having a problem with my idle.. when in neutral the car will rev to about 3000rpm then dump to about 1000 rpm then keep doing it constantly.. i ahve replaced the thermostat,idle air control valve,bled the antifreeze line,vaccum lines all tested no leaks.. im just stumped as to what would be causing this problem.. thx in advance, and sorry if this has been posted b4, just dont have time to search in the middle of class lol....
Old Feb 14, 2007 | 09:18 AM
lVlemphizStylez's Avatar
Default Re: Please help.. Idle issue (94Integra_Ls)
tps my friend..tps
Old Feb 14, 2007 | 09:19 AM
Default Re: Please help.. Idle issue (lVlemphizStylez)
throttle posistioning sensor?
Old Feb 14, 2007 | 09:27 AM
yes...it can also cause an irratic idle and jerkyness when deaccelerating. It's what's wrong with my car right now
Old Feb 14, 2007 | 09:43 AM
yes, when giving the car throttle or letting off of the throttle, it is very jerky...
thx for the info, its been driving me nuts trying to figure out what was causing it
Old Feb 14, 2007 | 09:49 AM
Just talked to my mechanic and he said that he had put the tps on his tester and everything came out 100% with no fail... could it still be the tps?
Old Feb 14, 2007 | 10:21 AM
anyone
Old Feb 14, 2007 | 10:59 AM
how did he test the tps?? If its not the IACV or a vacuum leak then its like 95% the TPS
Old Feb 14, 2007 | 12:08 PM
k thx
Old Feb 14, 2007 | 12:09 PM
one more question. to replace that do i have to replace the whole throttlebody? or can i just get the sensor
Old Feb 14, 2007 | 12:52 PM
robtackett's Avatar
I have the same problem on my new teg and my old one did the same thing. I am think it is probably the IACV like that one guy said. The seem to go bad on most integs around here at least.
Old Feb 14, 2007 | 01:13 PM
Default Re: (robtackett)
well, i replaced my iacv... didnt fix the problem
Old Feb 14, 2007 | 01:37 PM
Default Re: (94Integra_Ls)
Also on the throttle body there are 2 sensors.. the map sensor and i think the other one is the throttle posistioning sensor.. the one that i think is the tps is located on the back side of the throttle body facing the cab of the car, if i unplug that while the car is running the idle will drop and become normal, other than the fact that the car burns very rich when i do this.. the idle remains normal until i turn my car off and start it the next time, which when i start it the next time it begins the idle surgeing
Old Feb 14, 2007 | 02:18 PM
anyone??
Old Feb 14, 2007 | 07:10 PM
hello?
Old Feb 14, 2007 | 08:51 PM
will somone please answer me
Old Feb 14, 2007 | 09:11 PM
getting help here is non existent
Old Feb 14, 2007 | 10:01 PM
HELL ******* LO!!!!! ANYONE THERE??
hadehatch
Dec 4, 2024 01:46 PM
philep_cb7_91
Feb 21, 2010 11:28 AM
rcjustin
26
Feb 3, 2006 10:37 AM
kihun_cha
20
Sep 17, 2004 03:18 PM
Vp Special K
Apr 4, 2003 09:14 PM
